USB Problem via OnePlus 6T
  1. ahmetX
    Donut Feb 20, 2020
    ahmetX , via OnePlus 6T , Feb 20, 2020 :
    hi, my phone is oneplus 6t and i have problem. when i connect to any device via usb, the phone is not visible, can you help me?
  2. Caomhin
    KitKat Feb 20, 2020
    ahmetX likes this.
  3. ahmetX
    Donut Feb 21, 2020
    ahmetX , via OnePlus 6T , Feb 21, 2020 :
    USB debugging is already enabled.
    I cleared the USB port and type c port, but again the same
    Caomhin likes this.
  4. Caomhin
    KitKat Feb 21, 2020
    Caomhin , via OnePlus 6T , Feb 21, 2020 :
    Just wondering, are you using the OnePlus supplied cable or a generic cable?
    ahmetX likes this.
  5. Madnezz4Ever
    Jelly Bean Feb 21, 2020
    Madnezz4Ever , via OnePlus Community App , Feb 21, 2020 :
    What happens when you disable USB debugging?
    Are you trying to browse your files on the phone as you shouldn't need to enable it for that?
    Caomhin and ahmetX like this.
  6. ahmetX
    Donut Feb 21, 2020
    I use the cable from the original box of the phone
    Caomhin likes this.
  7. ahmetX
    Donut Feb 21, 2020
    There is no change when I turn off debugging.
    In the past, I used this feature very well.
    but now when I connect the phone to a computer or any device, I can no longer see my phone on the computer.
    I can't see it when I connect a USB flash disk to my phone.
    When I enter the usb preferences from the settings, I cannot make any changes as in the picture.
    Caomhin likes this.
  8. Caomhin
    KitKat Feb 21, 2020
    Just something to try, not sure if it will work, but if it does let us know.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    G_Huynh_Tinh likes this.
  9. ahmetX
    Donut Feb 21, 2020
    I did the same thing as you said, unfortunately, there was no change :(
    Caomhin likes this.
  10. ahmetX
    Donut Feb 21, 2020
    Still, thank you so much for helping me.
    Caomhin likes this.
  11. Madnezz4Ever
    Do you get a message on the PC and does it make a sound like it's supposed to?
    Have you tried another cable? Any USB type C cable will work.
  12. ahmetX
    Donut Feb 21, 2020
    When I connect the phone to the computer, there is no sound, yes I tried it with the original xiaomi type c cable, the result is frustrated.(
  13. Madnezz4Ever
    Weird as it's supposed to make a sound and if you go into device manager you should also see it device manager update once you connect the phone.
    The only thing I can think of is that the cable is no good or there's some setting on your phone that is causing it not to be detected. You could also have a bad driver on your PC.
    Try searching on Google Phone not detected on PC and try the solutions given. If all fails back up your data and factory reset your phone and hopefully that does it
    ahmetX likes this.
  14. ahmetX
    Donut Feb 21, 2020
    thank you you are helping.
    cable original cable, computer has not been tried on different computers, I do not see I am inserting flash disk with OTG. I think the only thing that comes to my mind is either software related or the type c input of the phone is somehow broken.
