USB Problems
  1. alrondoman
    Froyo Jun 21, 2017
    alrondoman , Jun 21, 2017 :
    when I connect my op5 to my laptop using the dash cable and enable file transfer my laptop doesn't show a new device connected. it's win10 fyi. only indication of a new device is in the eject media area there is an option listed as "Qualcomm Hs-USB Diagnostics 900E"
    some advice would be appreciated, thanks
  2. Android450
    Marshmallow Jun 21, 2017
    CeeTeePee and Salt505 like this.
  3. alrondoman
    Froyo Jun 21, 2017
    didn't see a pop-up about drivers installing tbh and I can connect to the laptop over Bluetooth but can't send or receive anything
    Salt505 likes this.
  4. Android450
    Android450 , Jun 21, 2017 :
    Did you have an older OP phone before the OP5? If so uninstall the drivers for that phone and try to get the OP5 drivers to install.
    Tokolozi and Salt505 like this.
  5. alrondoman
    Froyo Jun 21, 2017
    yes I had a op3 that I had no problem connecting before the op5... how would I go about removing those drivers and then prompting the op5 drivers to be reinstalled?
  6. Android450
    Uninstall the drivers should be under programs on windows in the control panel. Then just plug the OP5 back in and it should start installing the drivers
    Tokolozi likes this.
  7. alrondoman
    Froyo Jun 21, 2017
    been trying to uninstall the drivers for one of the Qualcomm Hs-USB Diagnostics 900e (COM3) which may not be the problematic one but I've got to go to bed so I'll try again tomorrow, thanks
    Android450 likes this.
  8. ddaharu
    Froyo Jun 21, 2017
  9. iNtEnSePL
    KitKat Jun 21, 2017
    iNtEnSePL , Jun 21, 2017 :
    so OP5 now needs another PC and can't work properly on the same PC with OP3?
    way to go!
    Shuller likes this.
  10. rajatdixit
    Gingerbread Jun 21, 2017
    rajatdixit , Jun 21, 2017 :
    It seems like other people are having similar issues. You probably got a reference phone and not the retail version. Can you go under Settings > About phone to check? You can also check by booting into recovery.
  11. alrondoman
    Froyo Jun 21, 2017
    checking about phone, shows me information such as the phone's status, specs such as ram and storage, OS and serial number and regulatory info. I don't see anything about reference or retail
  12. alrondoman
    Froyo Jun 21, 2017
    I updated the drivers for Qualcomm Hs-USB Diagnostics 900e and plugged in my op5 and no problem, thanks guys
  13. alrondoman
    Froyo Jun 21, 2017
    tried to connect again and am having the same problem now, without an option to update or uninstall drivers
  14. drohm
    Eclair Jun 21, 2017
    drohm , Jun 21, 2017 :
    D-bag much? :rolleyes:
  15. Alvie
    The Lab - OnePlus 5T Reviewer Jun 21, 2017
    Alvie , Jun 21, 2017 :
    Unlock your phone whilst plugged in to PC, In your notifications panel it should say USB for charging, click on that and choose Transfer Files
  16. iNtEnSePL
    KitKat Jun 21, 2017
    who, the OP5?, seems like it. It's a perfectly normal scenario. an user with both phones trying to connect them independently to one PC... what's so d-bag in it? :)
  17. dalexmuro
    Cupcake Jun 21, 2017
    dalexmuro , Jun 21, 2017 :
    I had the same problem and I solved it really easily : I restarted the phone and the PC, I activated the USB Debug mode on the Developer Options and set the Conectivity Mode on MTP Transfer Files, then I connected again the OP5 and it worked!
    scrubber likes this.
  18. sandesh3108
    Donut Jun 26, 2017
  19. Ashishmutha
    Cupcake Jun 26, 2017
    Ashishmutha , Jun 26, 2017 :
    Dual SIM problem. When you're talking over the phone on one SIM the Sim 2 shows not reachable
  20. wiebejosh
    wiebejosh , Jun 26, 2017 :
    enable developer mode on the phone, enable USB debugging, restart your computer and phone.
    worked for me
