Usb Tethering and Data transfer is not Working via OnePlus 7
  1. SurajitK1202
    Cupcake Jun 15, 2021
    SurajitK1202 , via OnePlus 7 , Jun 15, 2021 :
    I have been trying for soo long and did everything i could But still i cannot find the solution , as advised i also enabled the developer options and turned the usb debugging on but it's still not working , I need help asap
  2. Artemus.
    Community Hero 2020 Jun 15, 2021
    Artemus. , Jun 15, 2021 :
    Did you not enable USB debugging? o_O
  3. SurajitK1202
  4. Artemus.
    What're you trying to do exactly?
  5. SurajitK1202
  6. Artemus.
    Alright. What you do is, turn on USB debugging, plug in the phone to the PC/laptop, tap the notification saying "Charging this device via USB" and choose "File transfer", open Windows Explorer and open the phone's drive that should appear. If this is the first time you've done this, you'll have to install the drivers stored on the phone's drive and then it'll open up the files. Not sure if Android 11 changed things though.
  7. SurajitK1202
    That's the problem mate, once i plug the USB with my device my pc isn't showing my phone drive , it's getting charged Instead i guess it may be have something to do with 11 update , i mean it was all great before the update
  8. Artemus.
    I updated the instructions a bit. Forgot to mention the notification. I just did it myself and it worked perfectly.
    SurajitK1202 likes this.
  9. SurajitK1202
    Man i did everything you told , still not working though i have written to the customer care, waiting for their response , Anyways thanks a lot dude !
  10. Artemus.
    I mean... I told you how it worked for me. Make sure to keep USB debugging on or else it won't work. The screenshot you posted shows it's been turned off.
  11. SurajitK1202
    Okay , yeah i have kept it on that Usb debugging , maybe uploaded the wrong screenshot 🤦🏻‍♂️
  12. SurajitK1202
  13. Artemus.
    Mmm, nope. You should be good to go. Do you not get a notification when the phone is plugged in?
  14. SurajitK1202
    No man i use to get the notification before the update now it's only getting charged
  15. Artemus.
    Take a screenshot of your notification shade (blurring out any personal notifications).
  16. SurajitK1202
  17. akks
    KitKat Jun 15, 2021
  18. akks
    KitKat Jun 15, 2021
    Artemus. likes this.
  19. SurajitK1202
  20. akks
    KitKat Jun 15, 2021
    akks , Jun 15, 2021 :
    No need to enable usb debugging for file transfer.
