10
Answered Use "horizon light" on my Oneplus 7PRO as a notification indicator.
  1. V1572220436790
    Cupcake Oct 28, 2019
    V1572220436790 , Oct 28, 2019 :
    Hi all! Previously, Oneplus smartphones had a notification indicator. In the latest models it is not. The absence of this function worsens the experience of using a smartphone. I beg you to draw the attention of Oneplus and Oxygen OS employees to this function and add the ability to use "horizon light" as a notification indicator in oxygen os. I mean let this function work cyclically, not once during the receipt of a notification.
  2. Yuriy_Kovalenko
    Donut Jan 15, 2020
    Yuriy_Kovalenko , Jan 15, 2020 :
    I fully support the author of the topic!
    One could add the function of turning on the Ambient Display cyclically (once every 15/20/30/60 seconds), in the case of unread notifications, or integrate the same functionality into Horizon Light.
    Something similar was implemented by the XJIOP developer (https://play.google.com/store/apps/details?id=org.xjiop.oxygenaodmod&hl=en), but the application has limitations.
    I would like such functionality (at least the simplest) in Oxygen OS by default, I think it will be in demand on all OnePlus models after 6 models (6T / 7/7 Pro / 7T / 7T Pro / and future models).
    Support this topic with your comment if you would be interested!
  3. Aleksij Blinov
    Froyo Jan 15, 2020
    Aleksij Blinov , Jan 15, 2020 :
    Great idea! I think many people want to have this on their phone. This is much more convenient than flashing a screen once.
  4. yousmass
    Cupcake Jan 15, 2020
    Mike_Adriano, dim1973, juuux and 2 others like this.
  5. _d1mpash_
    _d1mpash_ , Jan 15, 2020 :
    I support it, after owning other devices with a notification indicator, this function on OnePlus is very lacking
  6. Mad1man
    Froyo Jan 15, 2020
  7. dim1973
  8. W1579081058300
  9. Pashtetus777
    Mike_Adriano and Aleksij Blinov like this.
  10. Mike_Adriano
    Cupcake Jan 16, 2020
  11. Yuriy_Kovalenko
    Donut Jan 22, 2020
  12. Gav_W86
    Starting Point Expert Community Expert Jan 22, 2020
    Gav_W86 , Jan 22, 2020 :
    You are posting on a user forum. You are not going to get a response from OnePlus people here.
    you can put a suggestion direct to OnePlus via Feedback feature in the OnePlus Community app (tap the red + button and select Feedback).
  13. vossti
    Eclair Jun 16, 2020
    vossti , Jun 16, 2020 :
    just upgraded from OnePlus 6 to 7pro and yes i really do miss that notification LED. it's really important. it's a no brainer that the horizon light should take over this function.
  14. ɢноѕтΘпе
    Starting Point Expert Community Expert Jun 16, 2020
    ɢноѕтΘпе , Jun 16, 2020 :
    You can use notify buddy to emulate the notification led.
  15. vossti
    Eclair Jun 16, 2020
    it's on play store?.. will definitely try it out...
  16. ɢноѕтΘпе
  17. vossti
    Eclair Jun 16, 2020
    does it actually read the actual content or just the fact that there's a message.?..
