Using OP3 since June-2016 Shall I upgrade to OP6
  1. Sridhar.Gundu
    Cupcake Apr 21, 2018
    Sridhar.Gundu , Apr 21, 2018 :
    Dear all
    Kindly suggest whether I can upgrade to OP6 or not, I am using One plus 3 since June-2016, Working fine and in good condition
    Regards
    Sridhar Gundu
  2. iNtEnSePL
    KitKat Apr 21, 2018
    iNtEnSePL , Apr 21, 2018 :
    first of all, OP6 is not released yet. No one knows final specs nor price.
    If I were you I'd wait, read reviews, check if there is anything new or substantially better than in OP3.
    If you are happy with your device and find nothing that it lacks right now, it's not worth to spend money for a new toy
  3. dineshsp04
    Gingerbread Apr 21, 2018
    dineshsp04 , Apr 21, 2018 :
    I am on the same boat as you. OnePlus 3 performs great on today's standards. it even plays PUBG well, so what is there in op6 that you want to buy? I suggest you wait for next iteration of the phone
  4. tortoise14
    Honeycomb Apr 21, 2018
    tortoise14 , Apr 21, 2018 :
    I m also using OnePlus 3 since June 2016.no problems at all.but my priority is camera.if 6 comes with good cameras,i will go for it. Huawei p 20 pro and p 20 will be beyond my budget (acc to price leaks in India).
    36dbldz and iNtEnSePL like this.
  5. ghostofcain
    Marshmallow Apr 21, 2018
    ghostofcain , Apr 21, 2018 :
    Have a look at the Huawei mate 10 pro or Honor View 10 both put petform the OP5T
  6. yashvardhan23
    yashvardhan23 , Apr 21, 2018 :
    if camera is priority to upgrade to op6 from op3 then why are you guys not considering lg v30? op6 will cost same i guess 44k.... newer processor every year that might reduce 0.006 sec in opening app not worthed.. lg's camera is excellent
    Marwadi_Rahul likes this.
  7. dermot33
    Ice Cream Sandwich Apr 21, 2018
    dermot33 , Apr 21, 2018 :
    Inhave tne op3 since release also and cant fault it, but its coming to the end of its lifecycle on terms of updates,I want the op6,but if price is too high Ill go elsewhere.
    Keeping an eye on nokia 7+ for Android one and promise of updates for three years,although not much of an upgrade in trms of performance should be enough in day to day use,no gaming.I wouldnt go honor or huawei due to lack of updates.
    36dbldz and dattaprasad.patil.88 like this.
  8. J1513597794949
    Donut Apr 21, 2018
    J1513597794949 , Apr 21, 2018 :
    better to wait 1 year more... technology will change like hell...be with your one plus 3 and get one plus 7 next year.
    G1510857028829 likes this.
  9. Arvind341
    Eclair Apr 21, 2018
    Arvind341 , Apr 21, 2018 :
    better wait for 6T, cause your OP 3 will work fine and some updates may receive till that
    dattaprasad.patil.88 likes this.
  10. Shubhaksh Kumar
  11. DARTH 007
    KitKat Apr 21, 2018
    DARTH 007 , Apr 21, 2018 :
    op6 still not worth it.
    I doubt if many people from the forum will upgrade to the 6.
    they have to catch new buyers
  12. dattaprasad.patil.88
    dattaprasad.patil.88 , Apr 21, 2018 :
    LGV30 is a good pick! However, there are lots of google cam mods available for op3. Install those and wait for Op6T or even Op7.
    Sridhar.Gundu and Marwadi_Rahul like this.
  13. yashvardhan23
    what mod is available can. you tell me. i have op3 using stock camera app... not that good
  14. dattaprasad.patil.88
    yashvardhan23 likes this.
  15. elanglois
    Lollipop Apr 21, 2018
    elanglois , Apr 21, 2018 :
    I suggest all you idiots without a mind of your own need to get off the Internet and social media sites and learn to think for yourself. Only YOU know your needs and budget requirements.
  16. theshinybeast
    theshinybeast , Apr 21, 2018 :
    zoestar likes this.
  17. Akhshay Srinivasan
    Nougat Apr 22, 2018
    Akhshay Srinivasan , Apr 22, 2018 :
    my suggestion would be..... go for OnePlus 6 .....great deal....
    But, as Mr. @elanglois perfectly mentioned ......, it's you who knows what's your budget and decide whether it's a bang for your buck or you're able to pay with ease ...... monetarily because OnePlus 6 comes with additional features as compared to its predecessors [e]1f44a[/e] hence would be proportionately expensive ..... (₹ 44,000 INR approx.)
    So, choose what suits you !
    Good luck [e]1f44d[/e]
    rk96 and Sridhar.Gundu like this.
  18. Harrshjoshi
    Cupcake Apr 22, 2018
    Harrshjoshi , Apr 22, 2018 :
    Thats the same with me. I m also a OP3 user since it got launched in 2016, but i wld like to say that my rear and front camera had become faulty and then the service centre guys told me that the compnay had got some faulty cameras which whey promised to replace for free(which they did) . There is not a single issue with this fone other than that.(which got solved in 2 days). Now the thing i fear is that wld the company have some faults in hardwares in OP6 ? Maybe or may not be. I will wait for 6T or OP7.
  19. Akhshay Srinivasan
    Nougat Apr 22, 2018
    Harrshjoshi
    Thats the same with me. I m also a OP3 user since it got launched in 2016, but i wld like to say that my rear and front camera had become faulty and then the service centre guys told me that the compnay had got some faulty cameras which whey promised to replace for free(which they did) . There is not a single issue with this fone other than that.(which got solved in 2 days). Now the thing i fear is that wld the company have some faults in hardwares in OP6 ? Maybe or may not be. I will wait for 6T or OP7.​
    definitely..... the notch or the waterproof body will have some critical reviews (means faults)...... so never worry.....
    wait till Op 7 ? I wholly appreciate your patience [e]1f44d[/e]
    Harrshjoshi likes this.
  20. sahil_sharma
    Gingerbread Apr 22, 2018
    sahil_sharma , Apr 22, 2018 :
    Hi,
    I have been using OP2 since October 2015. It works fine as daily driver today. Although I had to replace battery but still it works fine.
    If you are facing some major issue with OP3 or you want some new feature, then make sure to think smartly that investing that much money for that feature is worth it or not ?
