25
V4A for Android Marshmallow discussion group
Did V4A improve your sound quality?
Poll closed Nov 29, 2015.
  1. Yes, a lot!
    19 vote(s)
    45.2%
  2. A wee bit better
    4 vote(s)
    9.5%
  3. Not at all
    3 vote(s)
    7.1%
  4. Made it worse
    0 vote(s)
    0.0%
  5. HELL YEA!!!!
    7 vote(s)
    16.7%
  6. I don't use it
    9 vote(s)
    21.4%
  1. Evokkimus
    KitKat Nov 21, 2015
    Evokkimus , Nov 21, 2015 :
    All the credit goes developers of Viper4Android and especially the creator of Material Viper4Android, Viper4713
    Remade the thread for Material Viper4Android, because this particular version is updated for Android Lollipop and Marshmallow
    This is a discussion thread for Viper4Android, mainly for Android Marshmallow. I created this thread to reduce offtopic discussions in a certain custom ROM thread [​IMG]
    (mainly because of @jstepa [​IMG])
    Also remember that I am not the developer of V4A, just a user who was simply blown away of the sound quality
    You can discuss anything concerning Viper4Android for Marshmallow here (Issues, sound setups, mods etc.)
    We will mostly discuss Marshmallow here, but other Android versions are fine
    Setups
    @CAuday's setup
    Ping CAuday for any questions regarding this setup :)
    Screenshot_2015-11-21-19-12-00.png Screenshot_2015-11-21-19-12-07.png Screenshot_2015-11-21-19-12-14.png Screenshot_2015-11-21-19-12-20.png Screenshot_2015-11-21-19-12-28.png Screenshot_2015-11-21-19-12-46.png Screenshot_2015-11-21-19-12-50.png
    Zhuhang's setup
    http://forum.xda-developers.com/showpost.php?p=44577409&postcount=4642
    @Evokkimus's simple bass setup (Moderate UI)
    Screenshot_20160407-230152.png Screenshot_20160407-230157.png Screenshot_20160407-230201.png Screenshot_20160407-230209.png
    Tagging some people who encouraged me to use V4A: @CAuday, @@punto, @Nicolas_g134 (might have forgotten some :( )
    You can tag these people here for questions, they are far more experienced in V4A than I am :)
    correct me if you find something wrong in my posts :D
  2. Evokkimus
    KitKat Nov 21, 2015
    Before you start installing:
    Your SELinux usually must be set to "PERMISSIVE" http://forum.xda-developers.com/devdb/project/dl/?id=12506
    Also your system partition must be in ext4 for it to work (thanks to @@punto for the tip
    For Marshmallow, you need to install BusyBox (Not the one by "Stericson") https://play.google.com/store/apps/details?id=ru.meefik.busybox&hl=fi
    Some Custom ROMs may have this already installed, some may not
    Requirements
    Android Version: 5.x Lollipop - 6.x Marshmallow
    Root: Yes
    System Write Protection: Disabled (Usually already disabled when using a custom kernel or for HTC devices if you have S-OFF)
    Busybox: Yes
    SELinux: Permissive
    Install Instructions
    (User App/APK Method)
    1. Place APK on your Internal or External SD Card.
    2. Install the APK with any File Manager.
    3. Start V4A and install the driver of your choice.
    4. Disable LPA if prompted.
    5. Reboot Device.
    (System App/ZIP Method)
    1. Place ZIP on your Internal or External SD Card.
    2. MAKE A BACKUP, VERY IMPORTANT! Things can happen.
    3. Use TWRP Recovery to Flash the Zip File.
    4. Start V4A and install the driver of your choice.
    5. Disable LPA if prompted.
    6. Reboot Device.
    On both occasions, remember to grant Storage permission to Viper4Android on Marshmallow. You can do this by going to Viper4Android's app information and choosing permissions tab.
    Download 2.4.0.1
    Developer's writings
    I am not the original creator of V4A, my user name is simply a coincidence, I have been using my user name throughout the web even before I even heard about this App, regardless enjoy this Material Edition!
    Recommended Music APPs
    Google Play Music
    PowerAMP Music Player
    Spotify
    Pandora Radio
    Recommended Audio Equipment
    These are some headphones I personally recommend for an exceptional audiophile or close to it while still being a fair price, I recommend checking Amazon for prices.
    Over the Ear Headphones
    Audio Technica ATH-M50x
    Sennheiser HD 558
    Sennheiser HD 598
    In Ear Headphones (Wired)
    DUNU DN-1000
    Sennheiser IE 80
    In Ear Headphones (Bluetooth)
    Jaybird X2
    Ear Tips
    Comply
    Getting PowerAMP To Work
    PowerAMP will work on Normal and Compatible Mode.
    For Normal Mode you must Disable BOTH Direct Volume Control & BT Direct Volume Control even if you're on wired headphones, under "Settings>Audio>Advanced Tweaks" to Disable.
    For Compatible Mode you are free to use DVC but you must
    Enable MusicFX under "Settings>Audio>Advanced Tweaks", then under Tone/VOL you can trigger the MusixFX button and V4A will work.
  3. jstepa
    KitKat Nov 21, 2015
  4. jstepa
    KitKat Nov 21, 2015
    jstepa , Nov 21, 2015 :
    This thread could have been on Custom OPO Software category, no need for it to be Off Topic?
    There are discussions about browsers etc.
    GhilS and Evokkimus like this.
  5. CAuday
    Gingerbread Nov 21, 2015
    CAuday , Nov 21, 2015 :
    Does anyone want more encouragement to use viperfx over any other audiofx out there.. Cause i am telling you... It will make your earphone sound like a 10000 bucks one... Rs ofcourse... :D
    Ranjithsmart, GhilS and Evokkimus like this.
  6. Evokkimus
    KitKat Nov 21, 2015
    Well I put it in OffTopic, as V4A works for every Android really. Oneplus needs to add more categories [​IMG]
    jstepa likes this.
  7. CAuday
    If anyone wants... I could share the screeshots of the settings i am running on viperfx... I had tried different combinations and found this to be the best one...
    Evokkimus likes this.
  8. Evokkimus
    KitKat Nov 21, 2015
    Yes, please :D
    I'm currently only using the bass booster. (Beginner interface [​IMG])
    Nicolas_g134 likes this.
  9. CAuday
    What for??.. This Thread will do...
  10. CAuday
    You really have no idea what's coming broo... Wait... :D:D
  11. Evokkimus
    KitKat Nov 21, 2015
    No, the thread is just in the section "OffTopic", as there isn't really a better section for this, maybe the mods could move this to a different one :p
  12. jstepa
    KitKat Nov 21, 2015
    Ok, but Kudos for popping the thread cherry :p
  13. bhavinvis
    Ice Cream Sandwich Nov 21, 2015
  14. Evokkimus
    KitKat Nov 21, 2015
    bhavinvis likes this.
  15. bhavinvis
    bhavinvis , Nov 21, 2015 :
    Waiting.....
  16. iPusak Gaoq™
    Jelly Bean Nov 21, 2015
    iPusak Gaoq™ , Nov 21, 2015 :
    Gonna wait for custom SlimSaber Marshmallow build by kantjer as it the only (if i'm not mistaken) rom that have V4A build from source....
  17. CAuday
    First apply the expert mode... Then try these settings.... Ddc depends on the earphones you use... So you'll have to hit and try...
    bcks01 likes this.
  18. CAuday
  19. jstepa
    KitKat Nov 21, 2015
  20. CAuday
    @punto and jstepa like this.
