25
V4A for Android Marshmallow discussion group
Did V4A improve your sound quality?
Poll closed Nov 29, 2015.
  1. Yes, a lot!
    19 vote(s)
    45.2%
  2. A wee bit better
    4 vote(s)
    9.5%
  3. Not at all
    3 vote(s)
    7.1%
  4. Made it worse
    0 vote(s)
    0.0%
  5. HELL YEA!!!!
    7 vote(s)
    16.7%
  6. I don't use it
    9 vote(s)
    21.4%
  1. piyushsoni24
    Gingerbread May 3, 2016
  2. locxFIN
    KitKat May 3, 2016
    locxFIN , May 3, 2016 :
    You need to be more specific.
    Gaurav Rohilla and piyushsoni24 like this.
  3. piyushsoni24
    Gingerbread May 4, 2016
  4. locxFIN
    KitKat May 4, 2016
    locxFIN , May 4, 2016 :
    Tell me exactly what's wrong. I can't help if I don't know what the issue is.
    Gaurav Rohilla likes this.
  5. piyushsoni24
  6. piyushsoni24
    piyushsoni24 , May 4, 2016 :
    I was not getting clear audio, so i uninstalled v4a. Could you please help me installing it again.... I have oneplus 2, rooted, twrp recovery and selinux changed to permissive.
  7. euqinhcet
    Cupcake May 8, 2016
    euqinhcet , May 8, 2016 :
    Flashed V4A_2.3.4.0_Enforcing_Lollipop.zip with TWRP on stock, rooted M 6.0.1 Nexus 5x, with both permissive and enforcing and can't get driver to stick. Prompted to install after every reboot. App storage perms are on. Can anyone help? Thx
  8. euqinhcet
    Cupcake May 8, 2016
    Flashed V4A_2.3.4.0_Enforcing_Lollipop.zip with TWRP on stock, rooted M 6.0.1 nexus 5x, both permissive and enforcing and can't get driver to stick. Prompted to install after every reboot. App storage perms are on. Can anyone help? Thx
  9. sudip.k.datta
    Cupcake May 9, 2016
    sudip.k.datta , May 9, 2016 :
    I am on COS13. Seems Viper is not working properly though I have installed it correctly. The Poweramp settings are also done to use viper normally (disable DVC and BT DVC). With Poweramp, the Processing status is 'No' whereas with Google Play Music it's 'Yes'. Any solutions please ?
  10. piyushsoni24
    Gingerbread May 10, 2016
  11. piyushsoni24
  12. senegalas
    Ice Cream Sandwich Jul 4, 2016
    senegalas , Jul 4, 2016 :
    Does anyone know how to get irs samples working. It always says Cant find, tried putting in media/legacy/viper4.../Kernel, tried to put on sd. I even cant save or load profiles because it cant find them. Is this bug in app or I need to use black magic? Android 6, official, cm13 OP2. Im seriuos when I save profile and tried to load it cant find it and it doenst exist in folder.
  13. EdLikesBeds
    Gingerbread Jul 4, 2016
    EdLikesBeds , Jul 4, 2016 :
    Are you using a file manager app?
  14. senegalas
    Yes ES explorer pro
  15. EdLikesBeds
    Gingerbread Jul 5, 2016
    EdLikesBeds , Jul 5, 2016 :
    Alright I had exactly the same problem as you had even with es explorer. Try using solid explorer instead even if it's the trial version and put the needed things into the folder locations. It should work this way. There's a problem with es explorer accessing the right locations.
  16. senegalas
    Ice Cream Sandwich Jul 5, 2016
    senegalas , Jul 5, 2016 :
    What is exact location I need to copy? Media/legacy? I'm about to give up I tried everything, maybe you can do step by step tutorial? By the way viper itself can't save profile.
  17. senegalas
    @@punto @Tarfex Guys I have the same freaking problem. Viper can't see profiles and IRS files I tried everything to solve but no results, please help. I'm on cm13.
  18. EdLikesBeds
    any file manager besides es explorer and go to
    /storage/emulated/legacy/ViPER4Android/ and put the things in the appropriate folder. irs files into kernel and profiles to profiles.
  19. Tarfex
    Tarfex , Jul 5, 2016 :
    I think I posted the fix some where on the fourm. Its been so long I don't remember what I did. But I'll try later today and see if I can help
    senegalas likes this.
  20. senegalas
    Yeah, sad thing that I already have my viper folder with samples on both SD and legacy. But it still can't detect. Anyways thank you for a help. It must be bug because I don't see reason why it shouldn't work.
