25
V4A for Android Marshmallow discussion group
Did V4A improve your sound quality?
Poll closed Nov 29, 2015.
  1. Yes, a lot!
    19 vote(s)
    45.2%
  2. A wee bit better
    4 vote(s)
    9.5%
  3. Not at all
    3 vote(s)
    7.1%
  4. Made it worse
    0 vote(s)
    0.0%
  5. HELL YEA!!!!
    7 vote(s)
    16.7%
  6. I don't use it
    9 vote(s)
    21.4%
  1. bhavinvis
    Ice Cream Sandwich Nov 22, 2015
    bhavinvis , Nov 22, 2015 :
    Somehow for me, Viper4android not owrking..
    Everytime i install driver and reboot, it tells me to install driver again....
    Any help.......
    #61
  2. bhavinvis
    #62
  3. @punto
    @punto , Nov 22, 2015 :
    its becoz u havnt installed the v4a drivers....(as everytime it asks for installing the drivers) unless v4a drivers are installed properly u wont have any folder in ur phone.
    1) have u followed the steps i mentioned?
    2)have u set ur Selinux to "permissive" ?
    #63
  4. @punto
    #64
  5. bhavinvis
    Now its not asking to install Drivers......
    SELinux - Permissive
    I am on SultanXDA MM ROM.
    Not sure about system partition. How to check?
    #65
  6. @punto
    reboot and open v4a if it asks to install drivers again then somethings not right...
    do u have busybox installed?
    have u followed the steps i mentioned above? (u r in ext4 if u dont know what it is)
    #66
  7. bhavinvis
    #67
    @punto likes this.
  8. @punto
    i have tried in tugapower and it worked if it didnt work for u i will flash sultan's rom and check...
    which busybox have u installed?
    #68
  9. @punto
    #69
  10. bhavinvis
    A1 - Yes. I have busybox installed
    A2 - Yes. I can see two apps
    Now i have new problem.
    I was able to find out folder which was - / Storage / Emulated / Legacy / Viper4Android using inbuilt file manager....
    But even after root access it did not allow me to copy paste.
    I did same with ES ROOT EXPLORER --> Now i have Viper4Android folder but still cant load ur PROFILE....
    #70
  11. @punto
    verify whether v4a asks for driver installation again or not?
    open es file manager, make two folder inside Viper4android folder (one named "Kernel" and another "Profile") then open my folder, copy contents individually rather than copying the folder, and paste in their respective folder using pc
    #71
    bhavinvis likes this.
  12. bhavinvis
    Finally able to do it..
    Now will check whether it was worth the efforts or not.....
    #72
    @punto likes this.
  13. Evokkimus
    KitKat Nov 22, 2015
    Evokkimus , Nov 22, 2015 :
    Do you have your SELinux set to Permissive? This happened to me too at some point.
    Edit: Oh @@punto helped you already. Nevermind :D
    #73
    bhavinvis and @punto like this.
  14. @punto
    do rply if u notice any quality change
    #74
    Evokkimus and bhavinvis like this.
  15. bhavinvis
    Surely will do..
    Thanks for all the help
    #75
    @punto likes this.
  16. bhavinvis
    Officially HELL YEAHHH !!!!!
    #76
    @punto and Evokkimus like this.
  17. @punto
    u using my profile and my irs ? that i uploaded?
    #77
  18. bhavinvis
    #78
    @punto likes this.
  19. @punto
    then i have good ears...... also do tweak a but more for ur liking...
    i have set the viper ddc as EP-1 as it guves me the best result u can change them and see what matches ur headphone better.
    also my headphones have a low eesponse to basd thats why i have pushed the bass a bit high if u have good headphines then u may wanna tone down the bass...
    anyway thnx for using my profile.... :)
    #79
  20. hrangwala
    Gingerbread Nov 22, 2015
    hrangwala , Nov 22, 2015 :
    Hi guys i downloaded viper4android and whenever i open the app it keeps telling me to install v4a drivers and i have already done that and rebooted so many times but it keeps doing that. What should i do? I am currently on sultans android 6.0 cm13 ROM.
    #80
