25
V4A for Android Marshmallow discussion group
Did V4A improve your sound quality?
Poll closed Nov 29, 2015.
  1. Yes, a lot!
    19 vote(s)
    45.2%
  2. A wee bit better
    4 vote(s)
    9.5%
  3. Not at all
    3 vote(s)
    7.1%
  4. Made it worse
    0 vote(s)
    0.0%
  5. HELL YEA!!!!
    7 vote(s)
    16.7%
  6. I don't use it
    9 vote(s)
    21.4%
  1. @punto
    Ice Cream Sandwich Nov 24, 2015
    @punto , Nov 24, 2015 :
    yeahhh tuga is good i am asking whether the latest update of tuga is better than sultan.
    the thing i hated in tuga was not being able to change the vibrator intensity as i can in sultan.
    also according to u sultan 13 is the best "M" ? ( i was thinking about tuga coz i wanted to cnfrm whether v4a works with
    1)mx player or the
    2)default gallery player or
    3)poweramp
    on tuga or does it only work with the default music player as sultan does.
    Evokkimus likes this.
  2. Evokkimus
    KitKat Nov 24, 2015
    Evokkimus , Nov 24, 2015 :
    I cannot tell you which one is the best Marshmallow ROM. That would be unfair as I haven't tested them all. But I have heard good things about Marsh and Tuga. Also the CM13 nightlies are out, but I wouldn't use them yet.
    @punto likes this.
  3. @punto
    Let's dig more......
  4. thedrunkknight
    Evokkimus and @punto like this.
  5. @punto
    thnnn will flash and cnfrm... also is it compatible with extremebeats?
    and can it be used with data and cache as f2fs?
  6. thedrunkknight
    thedrunkknight , Nov 24, 2015 :
    What's that?
    No need to flash. Just install the apk file.
    Sorry, I didn't get your question. Maybe I don't have enough knowledge about file systems
  7. Evokkimus
    KitKat Nov 24, 2015
    Thanks mate. I just installed it and added my simple setup to OP.
    I am also using Shuttle, the paid version of course. An amazing player :)
    thedrunkknight likes this.
  8. @punto
    which v4a are u using? also which busybox? and is it compatible with mx player and others except default music player?
  9. Evokkimus
    KitKat Nov 24, 2015
    I'm using the V4A apk. My busybox is the one from Meefik.
    I haven't tried MX player but Shuttle works amazingly for me, among Google play music and stock music player.
  10. @punto
    hmnnn mx player not working for me....neither is poweramp....
    i am using sultan 13
  11. Evokkimus
    KitKat Nov 24, 2015
    Hmm weird. Why not try Shuttle? It's really good.
  12. @punto
    Ice Cream Sandwich Nov 25, 2015
    @punto , Nov 25, 2015 :
    i will.......
    edit: shuttle works fine.... but not mx player.. which video player r u using? is it v4a compatible?
  13. CAuday
    Gingerbread Nov 25, 2015
    CAuday , Nov 25, 2015 :
    It was working for me with the default music player in sultan's rom... And as far as i can remember i had to change it to s/w decoder to make viper4android work in mx player... I am not sure though..
  14. @punto
    nope not working even with sw decoder........
  15. CAuday
    Is it possible may be by any chance of asking about this directly to sultan??
    @punto likes this.
  16. Evokkimus
    KitKat Nov 25, 2015
    Evokkimus , Nov 25, 2015 :
    I'm using Shuttle premium for music. For videos I don't use really any player as I stream from Netflix and Youtube.
    But if I had to choose a vide player it would be VLC.
    @punto likes this.
  17. @punto
    I wish........... But he is damn busy I guess ROM building so he may not look into this
  18. Tricky
    Ice Cream Sandwich Nov 28, 2015
    Tricky , Nov 28, 2015 :
    I have searching for a while never really found an answer, but is there a way to get Viper4android to work with VLC?
  19. WangGang
    Gingerbread Nov 28, 2015
    WangGang , Nov 28, 2015 :
    So I got MaxxAudio(AudioFX). I had Viper4android and didn't like it because the stuff with SELinux. However, is the sound quality really that good? Was using speakers only so idk.
  20. raymanic1
    Gingerbread Dec 2, 2015
    raymanic1 , Dec 2, 2015 :
    guys I have a version of viper that seems to work with marshmallow and works with all players in normal mode, spotify and all, but I'm having the problem that I cant get .irs files to work, as viper seems to be looking in a different folder, as it saves profiles somewhere that isnt the /viper4android folder... any ideas?
