25
V4A for Android Marshmallow discussion group
Did V4A improve your sound quality?
Poll closed Nov 29, 2015.
  1. Yes, a lot!
    19 vote(s)
    45.2%
  2. A wee bit better
    4 vote(s)
    9.5%
  3. Not at all
    3 vote(s)
    7.1%
  4. Made it worse
    0 vote(s)
    0.0%
  5. HELL YEA!!!!
    7 vote(s)
    16.7%
  6. I don't use it
    9 vote(s)
    21.4%
  1. amoghkulkarni
    Honeycomb Dec 3, 2015
    amoghkulkarni , Dec 3, 2015 :
    Works well with Marshmallow. I am still using default music player. Hoping this would work on Rocket and Play music player. Thanks a ton.
  2. tamboli007
    Froyo Dec 3, 2015
    tamboli007 , Dec 3, 2015 :
    Working on sultan's rom with rocket player and pre installed player.Not working with MX player.
  3. Aletheia_
    Gingerbread Dec 5, 2015
    Aletheia_ , Dec 5, 2015 :
    Edit: Never mind, I solved my problem.
  4. tamboli007
    Froyo Dec 8, 2015
    tamboli007 , Dec 8, 2015 :
    V4A working on TugaPower rom with rocket player and stock music player but not working with MX player.
    Evokkimus likes this.
  5. tamboli007
    Froyo Dec 14, 2015
  6. @punto
    Ice Cream Sandwich Dec 16, 2015
    @punto , Dec 16, 2015 :
    really? it works with mx and poweramp on the latest marshmallow release?
  7. giocchi27
    Honeycomb Dec 24, 2015
  8. Evokkimus
    KitKat Dec 24, 2015
    Evokkimus , Dec 24, 2015 :
    Yea it works. I recommend using the LollliViper.zip flashable file to get it. It makes things easier.
    giocchi27 likes this.
  9. giocchi27
    Honeycomb Dec 25, 2015
    giocchi27 , Dec 25, 2015 :
    Even with Spotify and YouTube?
  10. Evokkimus
    KitKat Dec 25, 2015
    Evokkimus , Dec 25, 2015 :
    Not spotify I think but works on Youtube
  11. prastheicon
    Cupcake Dec 29, 2015
    prastheicon , Dec 29, 2015 :
    Viper is working but i cant load your profile :( pls help me to solve it. I am using Resurrection Remix Rom. pls pls pls
  12. @punto
    Ice Cream Sandwich Dec 29, 2015
    @punto , Dec 29, 2015 :
    did you follow the exact steps as mentioned?...... i am currently out of station..... giv me 2 days to return...... traveling 2 days by train in India is hectic.....
  13. prastheicon
    Cupcake Jan 2, 2016
    prastheicon , Jan 2, 2016 :
    Yes i followed exactly as it is mentioned
  14. prastheicon
    Cupcake Jan 5, 2016
    prastheicon , Jan 5, 2016 :
    Help pls if you have reached your destination
  15. @punto
    Ice Cream Sandwich Jan 5, 2016
    @punto , Jan 5, 2016 :
    google xtrememusic ..... and download the zip..... once done that, flash it in recovery..... then reboot and install v4a drives..... then again u need to reboot....pls do these and reply
  16. delpinsky
    delpinsky , Jan 5, 2016 :
    I have Resurrection Remix MM and I made it work after some troubles.
    Also, if you have personal profiles to load, be sure to change the permissions of these files, otherwise V4A can't read them and won't load them.
    Goto: data\media\legacy\ViPER4android\Profile folder
    There's also a guide to configure both V4A and MaxxAudio to make them work together:
    LINK
    it's in Italian but you can easily read what settings to use and in case Google translator helps.
    My headphones/speaker V4A settings:
    LINK
  17. haruhisuzimiya
    Honeycomb Jan 5, 2016
    haruhisuzimiya , Jan 5, 2016 :
    You don't need to flash all of that, LolliViper ZIP is all you ever need: http://forum.xda-developers.com/attachment.php?attachmentid=3431648&d=1438967541
    Flash this in your recovery, go to V4A app and install drivers, reboot and done.
  18. delpinsky
  19. haruhisuzimiya
    This ZIP already has the Material Design apk, along with other fixes for Lollipop/Marshmallow (like Selinux Enforcing fixes). Also if you dirty flash an update of the ROM you're on you do not need to flash it again.
    delpinsky likes this.
  20. prastheicon
    Cupcake Jan 7, 2016
    prastheicon , Jan 7, 2016 :
    Actually i have placed them in wrong place after placing them inside Viper4Android it shows in load effect profile but if i click it it doesnt load anything it just flashes and gives me the same as i have before
    In latest rom update firmware has changed will it cause any problem
    @punto likes this.
