Verizon/Visible connection on OxygenOS 12 via OnePlus 9
  1. nmh5001
    Donut Jan 22, 2022
    nmh5001 , via OnePlus 9 , Jan 22, 2022 :
    I installed the C.44 update hoping all of the "No Service" issues of the initial release would have been fixed, but I still could not connect to the Verizon network. After 2 hours of chatting with an online rep at Visible (Verizon's MVMO) she concluded I need a new SIM. Has anyone done this and had the phone connect successfully? Doesn't seem like that would be the fix considering it was still pulling APN information and when I downgraded back to OxygenOS 11, I have a connection again.
    stefanmaurer069 likes this.
  2. Tom9676
    Eclair Jan 22, 2022
    Tom9676 , Jan 22, 2022 :
    I was sent new sim did nothing. I have sent logs to Oneplus as they requested. Using Oneplus 9 5G
    nmh5001 likes this.
  3. Gamingtime1121
    Ice Cream Sandwich Jan 22, 2022
  4. Caomhin
    9 Series Expert, Participator of the Year Community Expert Jan 23, 2022
    nmh5001 likes this.
  5. Tom9676
    Eclair Jan 23, 2022
  6. Tom9676
    Eclair Jan 23, 2022
    Tom9676 , Jan 23, 2022 :
    I have indeed they asked me to send Feedback logs which i have done this weekend *#800#
  7. Caomhin
    Caomhin , via OnePlus 9 Pro , Jan 23, 2022 :
    No idea why they don't stay permanent on reboot. If you don't see any improvement after trying the suggestions given. Please send Bug reports and give Feedback on the issue back to the OnePlus OOS developers. So that they can investigate them.
    And you can also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for Email, Phone contact and online Chat details.
  8. nmh5001
    Donut Jan 23, 2022
    nmh5001 , via OnePlus 9 , Jan 23, 2022 :
    Per the reddit thread linked, it's a communication error between OxygenOS 12 and Visible. They are working on it. I think I will hold off on the upgrade until both parties can find a solution which doesn't require me to manually set APNs and swap out a SIM on each reboot.
    "still same after new sim but got this today from Visible
    Yes, according to the information provided, the device is not loading the APN due to the new version of the Android 12, since we are not compatible 100% with that version, however we are working on it. I know that is not the answer you need, but would you be kind enough to keep using the service in that way until we can be compatible at 100% with this version in the OnePlus"
    https://www.reddit.com/r/Visible/co...medium=android_app&utm_source=share&context=3
    Tom9676 likes this.
  9. Sacrin
    Cupcake Jan 25, 2022
    Sacrin , Jan 25, 2022 :
    Is all this to say that the new update seems to work fine if you have service with actual Verizon?
  10. Tom9676
    Eclair Jan 25, 2022
  11. rmendez011
    Gingerbread Jan 31, 2022
    rmendez011 , Jan 31, 2022 :
    Correct, Verizon works fine, LTE, 5G, VoLTE, SMS, MMS.
    Correct, this is only happening to Visible customers.
    Sacrin likes this.
