very big and strange problem of wifi, Bluetooth and network in Oneplus 6
  1. CHINRAJ
    Cupcake Dec 11, 2018
    CHINRAJ , Dec 11, 2018 :
    My wifi on phone doesn't work at all, and it doesn't even turn on.. Bluetooth also doesn't connect to the devices most of the time... And the mobile network goes off randomly and comes back again....
    V1545908822608 likes this.
  2. V1545908822608
    Cupcake Dec 27, 2018
    V1545908822608 , Dec 27, 2018 :
    I'm having the same issue with OnePlus 6.
    Ever since a month ago, it connects to a network for a few minutes and then crashes and can't find networks or Bluetooth devices.
    Resetting wiki and Bluetooth settings helps for a few minutes, restarting the phone helps for a few minutes and clear cache doesn't help at all.
    After a few minutes the wifi crashes no matter how much resetting and restarting and clearing I do.
    Couldn't find any information online about this.
    Opened a ticket and hoping for the best.
  3. CHINRAJ
    CHINRAJ , Dec 27, 2018 :
    I also reported an incident but didn't solve my issue... I've sent it to the service center now.... Seems like there's a problem with the motherboard...
  4. buddakine
    Cupcake Jan 2, 2020
  5. Caomhin , via OnePlus 6T Mirror Black , Jan 2, 2020 :
    Reset WiFi, Bluetooth, Mobile Network in Settings, System, Reset Options, restart the phone.
    You may have to reset up your Mobile Network APN and any Bluetooth devices,along with WiFi password or Mac address depending on the way way you connect.
  6. DrJMun
    KitKat Jan 2, 2020
    Kytharsis likes this.
  7. #7
  8. DrJMun
    KitKat Jan 3, 2020
    DrJMun , Jan 3, 2020 :
    Ahhh yes, of course.
  9. buddakine
    Cupcake Jan 15, 2020
    buddakine , via OnePlus 6 , Jan 15, 2020 :
    did all that still no wifi and bluetooth
  10. Caomhin
    KitKat Jan 15, 2020
    Caomhin , via OnePlus 6T , Jan 15, 2020 :
    Then try the following.
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.0. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
    Kytharsis and DrJMun like this.
  11. buddakine
    Cupcake Jan 16, 2020
    buddakine , Jan 16, 2020 :
    just did it.
    can't connect to WiFi still
  12. Caomhin
    KitKat Jan 16, 2020
    DrJMun likes this.
  13. buddakine
    Cupcake Jan 17, 2020
    DrJMun and Caomhin like this.
  14. #14
  15. buddakine
    Cupcake Jan 19, 2020
  16. B1541757117732
    Cupcake Feb 2, 2020
    B1541757117732 , via OnePlus 6 , Feb 2, 2020 :
    I have did everything, incoming and outgoing call didn't wark in 3G & 4G but it wark in 2G ! also when I try to see my mobile balence, reply""canection problem or invalid MMI code ""
  17. DrJMun
    KitKat Feb 2, 2020
    DrJMun , Feb 2, 2020 :
    Is this after 10.3.0 update? As @Kytharsis always suggest: did you reformat after you updated?
    Did you search the forum? This has been reported several times.
    Kytharsis and Caomhin like this.
  18. buddakine
    Cupcake Feb 5, 2020
  19. Kytharsis
    Nougat Feb 5, 2020
    Kytharsis , Feb 5, 2020 :
    Did you try my suggestion?
    Caomhin likes this.
  20. buddakine
    Cupcake Feb 5, 2020
    buddakine , via OnePlus 6 , Feb 5, 2020 :
    yes did reset network, restart, clear and wipe cache.
    reinstall os, etc.
    is it a hardware problem?
    OnePlus 6 is not even 2 yrs old.
