3
Very Very Low data speed one plus 6
  1. C1530382149719
    Donut Aug 28, 2018
    C1530382149719 , Aug 28, 2018 :
    I am getting very very Low data Speed on my One plus 6. on my other moto phone i am getting good data speed with same network Carrier.
  2. supra-bay
    Froyo Aug 28, 2018
    C1530382149719 likes this.
  3. Deactivated User
    Aug 28, 2018
  4. IQLAS
    Cupcake Aug 28, 2018
  5. C1530382149719
    Donut Aug 28, 2018
    yes my network is also.JIO. I think one plus 6 is duel 4g so it suppose to support 4g in both slots. one plus please fix this issue. my device is just 2 month old.not happy at all
  6. T1533916136641
  7. Sharry7
    Ice Cream Sandwich Aug 28, 2018
  8. NARASIMHA RAO ODUGU
    Froyo Aug 28, 2018
    santhoshgc75 likes this.
  9. Thaslij
    Donut Aug 28, 2018
    Thaslij , Aug 28, 2018 :
    C1530382149719
    yes my network is also.JIO. I think one plus 6 is duel 4g so it suppose to support 4g in both slots. one plus please fix this issue. my device is just 2 month old.not happy at all​
    put your sim on slot 1 .use the code *#*#4636#*#*
    Then check the network mode.make sure its on LTE.
    i guess it will work now onwards.
    Try on.
  10. jayd95
    Honeycomb Aug 28, 2018
    Addy1982 likes this.
  11. Q1535482431867
    Q1535482431867 , Aug 28, 2018 :
    I am also facing the same problem... From when did you are having trouble in network??
  12. arisin
  13. C1530382149719
    Donut Aug 29, 2018
    C1530382149719 , Aug 29, 2018 :
    it doesn't make any difference weather put in Sim slot 1 or 2 . having same issue on both slot. however both sim slot is 4g so it should work on both.
  14. C1530382149719
    Donut Aug 29, 2018
  15. C1535515146860
    Cupcake Aug 29, 2018
    C1535515146860 , Aug 29, 2018 :
    im too facing this problem .i have 2 sims airtel 4G and idea 4G . none of it is giving good net speed while they r working perfectly fine on the other phone . i have to keep switching on nd off from airplane mode so as to get net speed which lasts only for 2 min nd the problem continues.its been a month since i bought one plus . very dissatisfied .kindly fix d issue .
  16. C1530382149719
    Donut Aug 29, 2018
    that's what I don't understand if it is ISP problem then same sim card should not work on another cell phone as well but they are working on another cell phone with very good internet speed. it means this is not ISP or network carrier problem this problem seems will one plus 6 device. my device is just 2 Month old. I am very disappointed and frustrated. not happy at all. if problem not fixed I will not recommend one plus to anyone. one plus please do something.
    F_S_Shashi_Kiran_sWtC likes this.
  17. Thaslij
    Donut Aug 29, 2018
    Thaslij , Aug 29, 2018 :
    There is a difference whenever you place the sim on slot 2 .& type the code .you will see a change happening on sim placed in slot 1.for me this actually worked.my network was airtel. i couldn't get the network for several days & whenever it shifts to 3G from 4G , i had to restart the phone for getting 4G connection. so i tried this setting & it started working out.
  18. G_Viru
    Jelly Bean Aug 29, 2018
  19. NSryder4502
    Donut Aug 29, 2018
    NSryder4502 , Aug 29, 2018 :
    actually what's the issue I am facing the same issue since 1 week need a solution for this oneplus
  20. NSryder4502
    Donut Aug 29, 2018
    pls send me a screenshots
