Vibrate when call is answered
  1. dexterz92 Cupcake Jan 16, 2019
    dexterz92, Jan 16, 2019 :
    after updating my device to pie, i have started facing this issue. phone is not vibrating when call is picked. I have checked the settings and it is switched on.
    L1552310250415 likes this.
  2. trandaa Froyo Jan 16, 2019
    trandaa, Jan 16, 2019 :
    Have you tried to reboot?
    Have you cleared cache after update?
    Do your phone vibrate in other occasions (tapping, notifications, keyboard etc.)?
  3. dexterz92 Cupcake Jan 17, 2019
    dexterz92, Jan 17, 2019 :
    i just double checked, the phone is not vibrating at all
  4. trandaa Froyo Jan 17, 2019
    trandaa, Jan 17, 2019 :
    Try to check the vibration motor using factory mode. You can access it by typing *#808# in phone dialler. Swipe right and there is a "Vibration Test" tap on it, your phone should start to vibrate. If it won't, something is wrong with your vibration motor and you should contact your local service center
  5. dexterz92 Cupcake Jan 17, 2019
    It's working fine during the test only, otheriwse not.
  6. trandaa Froyo Jan 21, 2019
    trandaa, Jan 21, 2019 :
    Then ypu probably have some software issue. Is your system in any way modified?
  7. L1552310250415 Cupcake Mar 12, 2019
    L1552310250415, Mar 12, 2019 :
    i am also having the same issue. in ring tone it is vibrating, vibrate in touch is also working but when call answered then it does not vibrate. i did not have this issue few days back when i bought the phone last week.
  8. Anish kafle Cupcake May 27, 2019
    Anish kafle, May 27, 2019 :
    You guys need to enable Vibration from accessibility and then enable vibrate after connected in phone's dialer app or in settings
    BhuvaneshKannan likes this.
  9. BhuvaneshKannan Cupcake Jul 21, 2019
    BhuvaneshKannan, Jul 21, 2019 :
    Anish, I am on my OnePlus 7 pro ,Is there any way I could turn off touch vibration but turn on vibration when call is answered. ??
  10. vinobtech55 Cupcake Jul 22, 2019
    vinobtech55, Jul 22, 2019 :
    1. Go to Settings -> System -> Accessibility -> Vibration -> Set Touch Vibration to On
    2. Go to Settings -> Sound & Vibration -> Disable Touch Vibration
    3. Go to Call -> Settings -> Sounds and vibration -> Enable Vibrate after connected
  11. BhuvaneshKannan Cupcake Jul 22, 2019
    BhuvaneshKannan, Jul 22, 2019 :
    thanks you so much buddy it works and I have one more doubt can I get your contact information???
  12. vinobtech55 Cupcake Jul 22, 2019
    You can post your doubts here. I'll try to help you.
  13. Z1565256596199 Cupcake Aug 9, 2019
    Z1565256596199, Aug 9, 2019 :
    sometimes this problem occurs when you turns on the battery saving mode try to turn off the battery saving and then try.
