vibrating when charging using dash charger
  1. Shyam_226
    Cupcake Aug 22, 2017
    Shyam_226 , Aug 22, 2017 :
    when the phone is charging using dash charger, it is slightly vibrating on back. vibration stops after I removed charger. Please clarify.
  2. ritchiedrama
    Ice Cream Sandwich Aug 22, 2017
  3. akshay.mohol
    Shyam_226 likes this.
  4. G_Soham_shailesh_POqu
  5. Jayant Chowdhary
    remedy likes this.
  6. Rubenabc
    Honeycomb Aug 22, 2017
    Rubenabc , Aug 22, 2017 :
    It is caused by electrostatic loading, which is noticeable because the frame is made out of metal.
    Every device with a metal body, (iPads, other smartphones/tables) have this effect.
    Trust me, I'm an engineer.
    JoeyBimmel likes this.
  7. remedy
    KitKat Aug 22, 2017
    remedy , Aug 22, 2017 :
    Rubbish! It's likely to be due to defective house wiring of the power sockets. This could be dangerous.
  8. G_sourav_chakraborty_qZL
    Froyo Aug 22, 2017
  9. Rubenabc
    Let's do some research first okay?
    Sony officially responded to the same question:
    https://talk.sonymobile.com/t5/Xperia-XZ/Back-is-vibrating-while-charging/td-p/1166249/page/2
    And here some forms where they explain the same thing:
    https://linustechtips.com/main/topic/190222-weird-electrical-feeling-on-metal-htcs-when-charging/
    https://www.quora.com/Why-do-I-feel-a-slight-vibrating-buzz-when-I-rub-my-hands-over-my-MacBook-Air
    And to conclude a quote:
    "The electric charge is enough to stimulate touch receptors in your finger tips giving the sensation of a "rougher" surface. There are different types of sensory receptors in your skin and the information they send to your brain is what gets interpreted as a surface's "texture".
    You won't notice it on most other parts of your body as there is a much lower density of sensory receptors compared with your hands/fingertips and that there is variation in the thickness of skin and it's ability to resist electrical charges.
    Another example is getting a static shock that gives you a brief sensation of pain despite there being no damage to your tissues."
    So before calling my reply "Rubbish!" you should do your homework. Have a nice day, and try google the next time.
    Ow and trust me, I am an engineer ;)
  10. remedy
    KitKat Aug 22, 2017
    It's still a dangerous situation that needs the house electrical wiring to be checked for safety reasons. So I still maintain that what you are saying is rubbish.
  11. kev51773
    Donut Aug 22, 2017
    kev51773 , Aug 22, 2017 :
    Clearly nothing at all to do with house wiring. A well known, well documented phenomenon which has existed on many devices for many years.
    Rubenabc likes this.
  12. Rubenabc
    It is not dangerous at all, it is a common phenomenon, happening in devices of almost all manufacturers, Sony, Apple, Samsung, companies of E sigarets, HP, etc. etc.
    If you keep spreading the wrong idea that this feeling is a bad thing, a lot of people will start to worry unnecessary.
    I am glad to change my point of view if you come up with some data/evidence supporting that it is anything to worry about. But don't bother too much because you won't find it (from a reliable source). Don't be so dense.
    To the rest of the users here: The vibrating sensation you get is totally normal, use a grounded socket and charger if you want to avoid it. But it can do no harm to you or your phone.
