3
Vibration/Buzzing while Dash Charging
  1. hemanttiwari1012
    Eclair Jun 27, 2017
    hemanttiwari1012 , Jun 27, 2017 :
    Hi, I have just bought a OP5. I notice that when I am dash charging my phone, there is slight vibration (or a continuous buzz or a sensation) on the back side of the phone.
    Did anyone else noticed it in their OnePlus phones before? Is it a defect or just static electricity?
  2. G_Kalaidos
    Eclair Jun 27, 2017
    G_Kalaidos , Jun 27, 2017 :
    I don't notice anything on the phone. Except the charger adapter is slightly buzzing, but I've had this with all of my phone chargers in the past.
    Where is the buzzing located on the back of your phone? Do you use your phone while charging? Does it also happen if the phone is turned off?
  3. [email protected]
    Donut Jun 27, 2017
  4. Sahil_Aadarsh
    Cupcake Jun 27, 2017
  5. KashNarula
  6. sumanthsumi
    Froyo Jun 27, 2017
    sumanthsumi , Jun 27, 2017 :
    mee too having mild sensation (vibrations) when I touch backside of mobile while charging . is there any problem with my mobile?
    sriteja_9 likes this.
  7. bjoernbertelsen
    Gingerbread Jun 27, 2017
    bjoernbertelsen , Jun 27, 2017 :
    I experience this vibration as well. Also, if you put on a headset plugged into the phone while dash charging you can actually hear constant noise in the headphones. Turn off the dash charger then there is nothing.
    I'm not sure if this is a defect per definition or just a side effect of the huge amount of amps going into the phone.
  8. shubhayudatta
    Froyo Jun 27, 2017
    shubhayudatta , Jun 27, 2017 :
    Same here.
    If this is not the case with everyone, that means it could be a hardware defect, that means I might need to return it!
  9. shubham2712
  10. manuhalliwell
    Cupcake Jun 28, 2017
    manuhalliwell , Jun 28, 2017 :
    Same thing here with a regular charger, it's vibrating every xx seconds, and looking at the screen it looks like it's cutting off the charge and charging again some seconds after. So annoying!
  11. G_Adrian_Aiello_hxGo
    Honeycomb Jun 28, 2017
  12. Siddhantmasrani
    Donut Jun 28, 2017
  13. hemanttiwari1012
    Eclair Jun 28, 2017
    hemanttiwari1012 , Jun 28, 2017 :
    Try charging your phone with dash charge. Be barefoot and then touch your phone's back side.
    i notice that the buzzing doesn't happen when I wear something on my foot.
    Looks like an earthing issue to me.
    G_arun_krishnan_iKDO likes this.
  14. Chaitu4014
    Eclair Jun 30, 2017
  15. SathvikRoxxx
    Donut Jul 1, 2017
    SathvikRoxxx , Jul 1, 2017 :
    No way it's just that the charger is not connected with Earth wire... this issue is observed even in iPhones
  16. Sagar.Dhawan
    Cupcake Jul 4, 2017
    Sagar.Dhawan , Jul 4, 2017 :
    the issue is my phone as well, there is a constant light vibration while the phone is on dash charge. it also disconnects the charging (happened four times).
    Should I get the phone replaced. Any quick win here ??
  17. Kushhh
    Cupcake Jul 7, 2017
  18. G_Vinod_k_MhgF
    Cupcake Jul 7, 2017
    G_Vinod_k_MhgF , Jul 7, 2017 :
    I didn't face any issue during g calls, the buzz vibrate only happen when we attend the call.
    Call quality is good!
  19. mohitkala
    Cupcake Jul 7, 2017
    mohitkala , Jul 7, 2017 :
    same problem here and also my dash charge is also gets heated while charging and even phone too
  20. G_Harsh_Desai_JfLM
    Cupcake Jul 7, 2017
