7
Vibration is not working
  1. imago imaginis
    Cupcake Jun 26, 2019
    imago imaginis , Jun 26, 2019 :
    Same on my new OnePlus 7. I'm trying to get used to the phone but thinking of returning it because of this and other design inconsistencies...
    You cannot override a rather crucial functionality (vibrate) with a less important user choice (saving battery power). Users should not be punished and have the opportunity to choose, moreover since the profile is called (drum roll): "Vibrate".
    Mohasin_MK likes this.
  2. jonaswarnke
    Cupcake Jul 28, 2019
    jonaswarnke , Jul 28, 2019 :
    Yes, it was, I wasn't able to find the solution to my problem in the thread untill I saw this post!
  3. Artemus.
    Community Hero 2020 Jul 28, 2019
    Artemus. , Jul 28, 2019 :
    There's a difference between "finding" and "necroposting".
  4. J1558123370549
    Cupcake Aug 3, 2019
  5. Pandit10
    Cupcake Aug 8, 2019
    Pandit10 , Aug 8, 2019 :
    Thank you.
    Had to toggle on the switch from Accessibility and voila it worked. Thank you.
  6. F1562350299255
    Cupcake Aug 23, 2019
  7. ngydat
    Lollipop Aug 23, 2019
    ngydat , Aug 23, 2019 :
    Did you at least try the solution suggested in the thread ?
  8. CheffyB
    Cupcake Sep 1, 2019
    CheffyB , Sep 1, 2019 :
    If you have it on battery saver mode, it also will block the vibration function. FYI
  9. S1563548468699
    Cupcake Sep 21, 2019
    S1563548468699 , Sep 21, 2019 :
    Also if you have battery saver mode turned on vibration and haptic feedback will not work.
    One plus please change that as vibration for notifications shouldn't be affected by battery saver.
  10. K1561602774813
    Cupcake Oct 5, 2019
    K1561602774813 , Oct 5, 2019 :
    This worked
  11. N1571101743209
    Cupcake Oct 15, 2019
    N1571101743209 , Oct 15, 2019 :
    Have the same problem, i always set my phone in vibration mode until i noticed one time that the vibration is not working. I purchase my 7 pro online so I was thinking back then if i need to ship it back just to check until i went on this forum. While checking my phone doing this and that i realize that my phone was is Battery save mode. I tried to switch it off then the vibration works. Yay!
  12. otrtechguy
    Cupcake Nov 8, 2019
    otrtechguy , Nov 8, 2019 :
    Try turning off Battery save mode... I have been playing with this for several minutes now and think this is the problem.
  13. Y1578239078546
    Cupcake Jan 6, 2020
    Y1578239078546 , Jan 6, 2020 :
    Thank you. it has worked for me.👍
  14. V1579520170218
    Cupcake Jan 20, 2020
    V1579520170218 , Jan 20, 2020 :
    I managed to fix it by going to my keyboard settings (Google Keyboard) and offing vibration and oning it again
  15. sinapouchi
    Cupcake Mar 31, 2020
    sinapouchi , Mar 31, 2020 :
    Thank you so much for taking your time reviving this thread, you really helped me !
  16. shubhsona514
    Cupcake Sep 5, 2020
    shubhsona514 , Sep 5, 2020 :
    when we set our device on battary saver mode that time only vibrater work for call only and whrn the battary saver mode is off then still vibrater is not working so dont keep on battary saver mode of you always need vobrater for mob
  17. Mr.SINGH9460
    Cupcake Sep 21, 2020
    Mr.SINGH9460 , Sep 21, 2020 :
    Plz turn of power saving mode when you enable it the vibration is not working and when you diable it the vibration is working .
    This is work on my oneplus nord .
    Its too weird. Plz solve this issue as soon as possible .
  18. Artemus.
    Community Hero 2020 Sep 22, 2020
    Artemus. , Sep 22, 2020 :
    It's not weird at all. Battery saver doesn't actually conserve battery the way you think. It's meant to slow clock speeds and reduce as much excess background items as possible to squeeze out as much juice at low power. It doesn't increase your SOT.
    #38
    Q1609422820936 and Caomhin like this.
  19. the Curator
    Cupcake Dec 31, 2020
    the Curator , Dec 31, 2020 :
    Thanks a lot for your post...it finally worked even after trying out all the vibration activation modes...
    #39
  20. K1606763656129
    Cupcake Apr 8, 2021
    K1606763656129 , Apr 8, 2021 :
    Thank you so so much, I've been having this problem for over a month now and even contacted customer service with NO solution. I ended up factory resetting my phone and all! This was the solution after all that time, and I can't believe it took me this long to do something as simple as keeping battery saver off! Thank you so much!
    #40
