Vibration motor broken?
  1. dec1153
    Honeycomb May 23, 2019
    dec1153 , May 23, 2019 :
    Hi,
    The high vibration setting is making noise like this
    I just got it today. Is that normal? It only happens on high settings.
    thanks
  2. dec1153
  3. Hamzanehvi111
    Cupcake May 23, 2019
    Hamzanehvi111 , May 23, 2019 :
    is it a rattling noose as if something is loose
    i have the same issue on high vibration setting
  4. dec1153
    Yes. I contacted OnePlus. They are sending me a refund. You should do the same
  5. Hamzanehvi111
    what number did u call ??
  6. Hamzanehvi111
    please tell me the procedure to do so im suffering from this plague
  7. dec1153
    Honeycomb May 24, 2019
    dec1153 , May 24, 2019 :
    Customer support. Just explain the problem and they sort out a replacement. Bear in mind it takes 2 weeks to get a new one
