Vibration not working in battery saver mode
  1. O1575028162934
    Donut May 16, 2020
    O1575028162934 , May 16, 2020 :
    I am this facing issue for my OP 7 pro, when battery saver is ON then vibration is not working for all the notifications, touch except for incoming calls. Facing this from last couple of days, previously it was working.
    Also confirmed with one of the friend who owns OP 7 pro, its working on his cell.
    Any idea, is this the update/feature/bug?
  2. Arjun_Choudhry
    KitKat May 16, 2020
    Arjun_Choudhry , May 16, 2020 :
    Technically, it shouldn't work in battery saver mode. Haptics are a major source of battery draw and if the phone is in battery saver mode, the haptics should be turned off to save every bit of battery possible.
  3. O1575028162934
    Donut May 16, 2020
    Thanks Arjun for your reply, but same thing was working couple of days back and also its working on another cell. Also there hasn't been any OS update in couple of days.
    Was just curious is my cell has a bug or my friend's, does your cell also has same feature.
  4. Melkuse Daniel
    Ice Cream Sandwich May 16, 2020
    Melkuse Daniel , via OnePlus 7 Pro , May 16, 2020 :
    There is no bug or defect in your device, usually as said above battery saver turns off vibration (haptic feedback), limits the screen brightness then usual and also turns off the tap sound if enabled.
    By controlling these features for a while the battery performance can be last little longer where these feature drain battery higher than the normal.
    TheMystic and O1575028162934 like this.
  5. #5
  6. Melkuse Daniel
    Welcome bro, if your friend's device vibration still works even after turning on the battery saver then your friend's device might have some bug or issue,
    You can have a look at the above screenshot which clearly states that some of the features which consume much of battery power will be restricted to save battery backup.
    So your device is working fine with no issues, no need to worry in future.
    Stay safe, Have a nice day...
  7. #7
    TheMystic likes this.
  8. Melkuse Daniel
  9. O1575028162934 , via OnePlus 7 Pro , Mar 27, 2021 :
    Hi guys,
    Hope you are healthy and safe!
    From last couple of days vibration has started working in battery saver mode.
    No idea what has happened, previously it didn't vibrated.
    Can anyone help.
    Thanks
  10. Bobbie63
    Marshmallow Mar 27, 2021
    Bobbie63 , Mar 27, 2021 :
    It shouldn’t vibrate, what if you restart your phone?
    Artemus. likes this.
  11. #11
  12. Bobbie63
    Did you update to Android 11 earlier this week?
    oh and try to use the reply button so the one you answer to gets notified.
  13. O1575028162934 , via OnePlus 7 Pro , Mar 27, 2021 :
    Didn't got the update yet.
    Bobbie63 likes this.
  14. Bobbie63
    Ok, tbh I have no explanation why the vibration all of a sudden started working and could advice you to do all kinds of trouble shooting. I think though it’s easier to wait for the update and check if the issue still remains. I expect you’ll get the update within a week, maybe a week and a half.
  15. O1575028162934 , via OnePlus 7 Pro , Mar 27, 2021 :
    Okay, will wait for the update.
    Thanks for response.
    Artemus. and Bobbie63 like this.
  16. O1575028162934 , via OnePlus 7 Pro , Mar 30, 2021 :
    Hi guys,
    Found the issue, if anyone service is enabled in accessibility menu then cell will vibrate in battery saver mode.
    In my case, System -> Accessibility -> Volume Key shortcut was enabled, had to just disable it and now in battery saver mode there is no vibration anymore.
    Thanks
    PSS18 likes this.
  17. T1565080561451
    Cupcake May 5, 2021
    T1565080561451 , May 5, 2021 :
    Hey, I want to stop all vibrations in the phone (like wrong fingerprint input, dragging the youtube seek bar in a video with timestamps, etc., etc.) Just like the vibration settings in battery saver mode. Can I replicate it to normal mode>?
  18. PSS18
    Cupcake May 6, 2021
  19. O1575028162934 , via OnePlus 7 Pro , May 6, 2021 :
    If you want everything same as battery saver mode, then directly use saver mode, why to use normal mode.
