Vibration patterns not working
  1. Sylvain Doyon Cupcake Jun 17, 2019
    Sylvain Doyon, Jun 17, 2019 :
    Hi , I have only one vibration pattern working on my Oneplus.7 Pro. Was working before... Anyway to restore pattern ? The only one working is "mm-mm-mm".
    Thanks !!
  2. Aakash047 Froyo Jun 17, 2019
    Aakash047, Jun 17, 2019 :
    If you're using the ringtones provided in the device, dynamic vibration will work. If you use your own downloaded ringtone it will only use the regular vibration pattern.
    If you're using device ringtone and it's still not working try restarting the device or contact customer support.
