Vibration with custom notification sound via OnePlus 7 Pro
  1. TDC94
    Cupcake Apr 12, 2021
    TDC94 , via OnePlus 7 Pro , Apr 12, 2021 :
    Hi,
    I have custom notification sounds for call sms and notifications on my OP7 Pro with latest updates.
    The problems is that I am not able to get a vibration notification with custom sms and notification sounds.
    The vibration seems to be integrated into the notification sound itself because when I try the default sound it does vibrate.
    This is especially annoying because if I set the alert slider to 'vibrate' I do not get a notification at all unless its a call.
    Just to be clear I would like the vibration only when the alert slider is set on 'vibrate'. However, I wouldn't mind having it vibrate when its also on 'ring'.
    Is there a way to fix this?
    Thank you.
  2. Artemus.
    Community Hero 2020 Apr 12, 2021
    Artemus. , Apr 12, 2021 :
    Which update?
  3. TDC94
