vibrator glitching sound!
  1. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    Lakshya_mandovra_1995 , Jan 23, 2018 :
    hi everyone,
    i m observing weird kind of vibration glitching sound at strong intensity level.
    i had no physical damage on my op 5
    do anyone faced this kind of issue?
    pls help.
  2. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
  3. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    are you sure? don't you think its an hardware issue?
  4. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
  5. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    oh , but do you get the same glitching sound while getting incoming calls too?
  6. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
    G_Mrinmoy_Das_irwY , Jan 23, 2018 :
    No. I don't face this issue while getting a call. It's only when I am typing something and a notification arrives, the vibration glitches. I have also raised an issue here regarding this!
  7. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    oh, actually i was thinking go to service center to get it rectified because earlier i thought it due my tempered glass but after i removed it the issue is still there
  8. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
  9. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    yeah after Oreo update i noticed this is earlier everything was fine.
    what about you? When did u encounter with this issue?
  10. The1Lion
    Marshmallow Jan 23, 2018
    The1Lion , Jan 23, 2018 :
    So you think your phone has something to do with the behavor of your vibrator? :confused:
    Oh, did I misread that? :p
  11. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
    Same! This is just the initial update for Oreo. It will take time for the ROM to get stabled. I hope, the major issues will be fixed soon.
  12. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    so did you go to service center for this issue?
  13. jaivaghela
    Ice Cream Sandwich Jan 23, 2018
    jaivaghela , Jan 23, 2018 :
    I have a similar issue with my OP5, only with in coming calls as the phone vibrates it makes a sort if rattling sounds, like some hardware is rattling, its a bit strange and irritating, and the phone had not been dropped or experienced any damage of any sort.
  14. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
  15. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    exactly same bro. very irritating.
    jaivaghela likes this.
  16. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    okay but how did u come to know its a bug?
  17. Lakshya_mandovra_1995
    Donut Jan 23, 2018
    are you facing this issue after Oreo update?
  18. jaivaghela
    I wonder if it could be a fault of the vibration motor or something around it becoming loose and making contact with it. My wife's OP5 is fine so maybe only affecting a few devices it seems.
  19. G_Mrinmoy_Das_irwY
    Donut Jan 23, 2018
    Because many are facing the same issue and raising problems after Oreo update here in this forum. There's a very low probability that all their and our phones where damaged at the same time.
  20. jaivaghela
    It's still the same, doubt it's software, from the way it sounds I'm pretty sure it's a hardware issue.
