2
Virus scanner
  1. ayan1d
    Donut Aug 29, 2015
    ayan1d , Aug 29, 2015 :
    i am having a problem with a ad bar kind of thing which keeps on coming every now and then on my screen.It stays for a few seconds then vanishes on it own.If i click on the add then it redirects to a url called www.googleadservices.com/... which ultimately redirects to the advertisers page.The ad bar also has a link to optout, but it takes me to a page www.tracker.tpc.re/optut/mobile/.... which is not available. Can anyone help?
    neerajlag likes this.
  2. rebokz
    Froyo Aug 29, 2015
    rebokz , Aug 29, 2015 :
    In the end there's really no point, your just going to drain your battery searching for a virus you'll probably never get.
  3. yogeshyahoo
    Gingerbread Aug 29, 2015
    yogeshyahoo , Aug 29, 2015 :
    Yes,
    You can service without Antivirus also but just need to clean up you phone regularly
  4. 2ASIAN4U Studios
    Eclair Aug 29, 2015
    2ASIAN4U Studios , Aug 29, 2015 :
    I have my antivirus mainly because it INCREASES performance. I'm running 360 Security, a popular Android security app with a 99.9% detection rate. It's made by a Chinese cyber security company (which is fitting since OnePlus is a Chinese company). It comes with a bunch of device optimizers such as app optimization, CPU cooldown, startup managers, junk file and cache cleaner, etc (that's how it speeds up my phone). It works great for me, my battery life hadn't dropped since. I think it's one of the top Google Play apps, try it out.
  5. ashish1107
    Froyo Sep 1, 2015
    ashish1107 , Sep 1, 2015 :
    Im facing the same issue any solutions for this guys without rooting or formatting..
  6. ixub
    Cupcake Sep 28, 2015
    ixub , Sep 28, 2015 :
    I am in the same situation with avast security, without any new apps downloaded. Its started yesterday only HBO GO were installed at the weekend,
  7. andzol
    andzol , Sep 28, 2015 :
    Hi, I'm having the same issue.
    I never saw this kind of virus so far.
    The banner ad pop on the top of ANY application or interface. (unbelievable)
    NO apps have been installed in this week, however the device is allowed to install apps from 3rd party sources.
    I haven't find the app in the settings>apps>running
    No virus scans found it so far.
    The malware runs Adsense ads, and in the opt out section there is www.tracker.tpc.re url
    Pls help
  8. dasridha
    dasridha , Sep 28, 2015 :
    Hi, I am facing a similar issue. Didn't install any apps in recent times but getting this problem from today.
    Please help.
  9. keithnyc
    Moderator Moderator Sep 28, 2015
    keithnyc , Sep 28, 2015 :
    Brett, what about AVG?
  10. aakashjhaveri
    Lollipop Sep 28, 2015
  11. TeamValor91
    Community Veteran Sep 28, 2015
    TeamValor91 , Sep 28, 2015 :
    Old post. Use ESET. Rated the best AV-Scanner.
    keithnyc likes this.
  12. Slatter191
    Slatter191 , Sep 28, 2015 :
    I don't feel so, would hog resources and drain battery, if in doubt connect to lap and scan using its AV, Anti malware.
    iTrollz likes this.
  13. keithnyc
    thanks...just switched out of AVG and the others to ESET. Cheers, buddy
    TeamValor91 likes this.
  14. TeamValor91
    Cheers!
  15. Skf123
    Marshmallow Sep 28, 2015
  16. Skf123
    Skf123 , Sep 28, 2015 :
    Unfortunately that is incorrect
    http://fortune.com/2015/07/08/google-play-fake-app/
    There was also a flashlight app that was selling your location details to the Chinese, not sure if that's been pulled yet but itwas still up a good few months after it was 1st found out.
  17. andzol
    I tried Eset, Avast, 360, AVG neither recognized. Any update others?
  18. andzol
    Cupcake Sep 30, 2015
    #38
  19. badger906
    Jelly Bean Sep 30, 2015
    badger906 , Sep 30, 2015 :
    not necessary. unless you're the type of person who clicks random links and down loads random apk files..
    #39
  20. andzol
    Cupcake Oct 6, 2015
    #40
