[Submitted] Vision comfort not getting enabled
  1. Nikhil_Bhilai
    Honeycomb Dec 14, 2020
    Nikhil_Bhilai , Dec 14, 2020 :
    Vision comfort is not getting enabled on it's own in custom timings or manually and sometimes it doesn't get disabled on it's own in custom timings or manually. In both the cases, i have to restart my phone!!! Pathetic software experience on OP 8T!!! Spent my hard earned money for this experience ✌️ Great job OP ✌️ Kindly fix this issue!!!
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Dec 15, 2020
    Suhas Klkrn555 , Dec 15, 2020 :
    It would be our pleasure to resolve the issue that you are facing, as we have contacted you for the required information to analyze it further via direct message.
    Thanks & Regards,
    Suhas.
    Nikhil_Bhilai likes this.
  3. Suhas Klkrn555
    The issue reported by you is being taken care by our developer team and they are currently working on this. We will get back to you in case we would need more information.
    Thanks & Regards,
    Suhas.
  4. taneheh
    Cupcake Dec 16, 2020
    taneheh , via OnePlus 8 Pro , Dec 16, 2020 :
    I have almost same problem(?) here. I put vision comfort on and every time when i unlock my phone the screen is white and will slowly turn into "vision comfort" mode.
    Is it a bug or should it be like this. Because i would like the screen to be on vision comfort all the time, even when i unlock my phone.
