13
visual voicemail on OnePlus 7 pro
  1. O1541079600546
    Cupcake Jul 25, 2019
    O1541079600546 , Jul 25, 2019 :
    Yes. 1+ needs to work with T-Mobile to make sure this feature works right out of the box no matter where you buy your 1+ phone.
  2. femotely
    Donut Jul 29, 2019
    femotely , Jul 29, 2019 :
    Just tried this and it worked!!! I have been trying to get native VM to work since I got the phone!!! THANKS!!!
    nrschoen likes this.
  3. ZRXINLA
    Donut Aug 11, 2019
    ZRXINLA , Aug 11, 2019 :
    It's a trap! it only works fine until you reboot once or twice then it doesn't. :mad:
  4. ihaveabu
    Donut Aug 23, 2019
    ihaveabu , Aug 23, 2019 :
    I tried all the steps above and it's not working for me. Stuck on the vvm can't activate screen. I'm on an unlocked 7 Pro. On my unlocked 6T, the moment the SIM is inserted, the VVM tab shows up and all my voicemails populate it. I had to install T-Mobile's vvm app initially on my 6T and afterwards everything worked fine in the stock phone app.
    But the moment I switch the SIM to my 7 Pro, it says that vvm can't activate.
  5. mestizonline
    Cupcake Sep 7, 2019
    mestizonline , Sep 7, 2019 :
    I also had these problem "Can't activate visual voicemail" on my New unlocked OnePlus 7 Pro. Is this a T-Mobile issue? It works with my OnePlus 6T before.
  6. ZRXINLA
    Donut Sep 9, 2019
