VOLTE and VOWIFI feature stopped working after 10.3.8 update in OnePlus 6 via OnePlus 6
  1. abhinav-vats
    Cupcake Feb 6, 2021
    abhinav-vats , via OnePlus 6 , Feb 6, 2021 :
    After the update of 10.3.8 in my OnePlus 6, the update corrupted my primary SIM network which caused no more functionality of VOLTE and VOWIFI.
    Has anyone else faced the similar issue? If yes, then how you resolved it?
  2. B_Wrath
    Junior Moderator Junior Moderator Feb 6, 2021
    B_Wrath , Feb 6, 2021 :
    Can you both in the network settings?
  3. abhinav-vats
    Cupcake Feb 6, 2021
  4. B_Wrath
    Sorry. Can your see both options in the network settings?
  5. abhinav-vats
    Cupcake Feb 6, 2021
    Yes- And both the features are toggled on too. My secondary sim is working fine and offering both the features which was kept off at the time of update FYI.
  6. B_Wrath
    What is your primary SIM provider? Were you able to use VoLTE before the update on your primary SIM ?
  7. abhinav-vats
    Cupcake Feb 6, 2021
    Primary sim service provider is Airtel India and yes I was able to use both VOLTE and VoWiFi features prior to the update. Even seconds ago before I had to reboot the device to compete the update.
  8. Max.Mar
    Jelly Bean Feb 6, 2021
    Max.Mar , Feb 6, 2021 :
    Try to reset you network settings under settings and than reboot.
    B_Wrath likes this.
  9. abhinav-vats
    Cupcake Feb 6, 2021
    Already done. So is the factory reset.
    Currently in communication with the service provider who have stated that the problem arose due to the update patch that scrambled the network settings to the core.
  10. B_Wrath
    I don't have the issue. I too updated to 10.3.8 and everything is alright. I too use an Airtel sim.
  11. abhinav-vats
    Cupcake Feb 6, 2021
    See- that's the beauty of the concern. I even went to the OnePlus service center to get the problem fixed, but they deflected it to the service provider. So, now I am taking up it with the service provider who has no choice but to solve the issue as I have already paid to OnePlus but I my service provider want me as its customer.
    OnePlus is done with it and so am I.
  12. B_Wrath
    Or probably might have been a freak coincidence.
    Airtel is no saint. I have had many issues with them.
    In any case, type *#*#4636#*#* and check if the volte and VOWIFI buttons are on.
  13. Raresch
    Ice Cream Sandwich Oct 25, 2021
    Raresch , via OnePlus 6 Midnight Black , Oct 25, 2021 :
    Hi,
    I wanted to turn on my VoLTE and VoWifi features in my OnePlus 6 and started to search threads and I've found this old one.
    I've used your code (*#4636#*#*), and when I reach the settings panel, both volte and VoWifi options are turned off and grayed out. Do you know how to turn them on?
  14. B_Wrath
    Junior Moderator Junior Moderator Oct 25, 2021
    B_Wrath , Oct 25, 2021 :
    Then you need to contact your network provider. They have to enable it.
  15. Raresch
