volte issue
  1. Ajmal_Raffi7795
    Eclair Nov 17, 2019
    Ajmal_Raffi7795 , Nov 17, 2019 :
    I couldn't make calls from my phone, if I try to make a call it will cut instantly, then I have noticed that volte isn't supported, so please give me solution for this issue.
  2. pablofg1978
    Spanish POC Assistant Head Moderator Nov 17, 2019
    pablofg1978 , Nov 17, 2019 :
    This is a community forum, not support.
    If you want help from the community you will need to give more information about your issue
  3. Ajmal_Raffi7795
    Eclair Nov 17, 2019
    what and all information you want?
  4. pablofg1978
    Where are you from? what version of Oxygen are you using? What carrier do you have? Was it working before? Did you contacted your carrier?
    Ajmal_Raffi7795 likes this.
  5. Ajmal_Raffi7795
    Eclair Nov 17, 2019
    pablofg1978
    I'm from India, using jio sim card I keep the sim on first sim slot, and 2 days before it has worked
  6. pablofg1978
    Do you have data enabled on that sim?
  7. Ajmal_Raffi7795
    Eclair Nov 17, 2019
  8. pablofg1978
  9. Ajmal_Raffi7795
    Eclair Nov 17, 2019
    yep they told me like you have to contact on oneplus
  10. pablofg1978
  11. eye842
    Lollipop Nov 18, 2019
