3
VOLTE missing oneplus 7 pro
  1. Lusnie
    Cupcake May 22, 2019
  2. uvalml
    Froyo May 22, 2019
    uvalml , May 22, 2019 :
    Did a factory reset didnt help.
    One my plus 6 it is working with the same sim
  3. Mariusz Nocon
    Cupcake May 23, 2019
  4. everkurt
    Honeycomb May 23, 2019
  5. mogdaN
    Donut May 23, 2019
  6. bogasa
  7. mogdaN
    Donut May 23, 2019
    mogdaN , May 23, 2019 :
    VoWiFi is working for me. Make sure you enable it in the phone settings as mine was disabled by default. Also if it doesn't work check with Orange. I don't remember if there was a toggle in MyOrange online (not the mobile app) to enable VoWifi. If there's no such option you'll have to enable it on another phone which is officially supported first, like a S9 or something. Hope it helps
  8. bogasa
    bogasa , May 23, 2019 :
    You are right! I found that setting and indeed it was disabled by default. Thank you!
  9. Hutch81
    Eclair May 29, 2019
    Hutch81 , May 29, 2019 :
    I have the voLTE switch enabled and I see it on my TMobile sim slot but for Verizon sim slot ....Verizon just has the vowifi not VoLTE everything works except MMS messages. Any idea on how to fix this?
  10. jaqob81
    Cupcake May 30, 2019
    jaqob81 , May 30, 2019 :
    Hi
    I try to enable the volte by the settings and i call the carrier zain in kuwait to enable it but still not working and i i have befor op6 same issue any one in kuwait and he have volte working
  11. justwondering
    Gingerbread May 31, 2019
  12. justwondering
  13. pgrey
    Ice Cream Sandwich May 31, 2019
    pgrey , May 31, 2019 :
    Isn't that basically a "downlevel" APK, for the Logkit module?
    I'm wary, of "down-leveling" my Logkit, because it's used if you need to report pretty much ANY bug, this is the interface you use to start/generate/save trace-logs, to send to OP...
    I wonder why they haven't enabled this "properly", in the Logkit module, for the OP7(Pro)?
  14. justwondering
    justwondering , May 31, 2019 :
    It does seem strange, considering my 5t, 6 and my now sold 6t, all have that feature bulit in.
    But using the APK does work and also worked with my mobile network provider with my global OnePlus 7 Pro.
    I'm sure though if OnePlus made a new version of the APK, then it could be overwritten.
  15. uvalml
    Froyo May 31, 2019
    uvalml , May 31, 2019 :
    My overall conclusion.
    Installing the logkit apk finally got the volte into the settings, using *#800# .
    My phone company doesnt support the op7 pro, or any oneplus.
    I got lucky when it worked on my op6, because it shouldnt.
    Hopefully they will add this feature soon, they support only galaxy and iphones.
    Im from israel using pelephone company.
  16. F_Castro_EICP
    Gingerbread Jun 1, 2019
  17. justwondering
  18. Steven_Petrillo
    Steven_Petrillo , Jun 1, 2019 :
    Do you see WiFi calling also?
    #38
  19. G_Todd_McLaughlin_OSQV
    Gingerbread Jun 2, 2019
    #39
  20. mirheldt
    Cupcake Jun 10, 2019
    mirheldt , Jun 10, 2019 :
    Any official statement why basically all EU sold handsets Oneplus 7 PRO have VoLTE feature disabled? There gotta be a reason for it. I mean what possible issues can pop-up when enabling it through installing logkit apk? Is there a OTA update in the works? I'd love to have VoLTE enabled but don't wanna deal with unexpected problems.
    #40
