3
VOLTE missing oneplus 7 pro
  1. justwondering
    Gingerbread Jun 10, 2019
    justwondering , Jun 10, 2019 :
    My Chinese version of the oneplus 7 Pro also had the feature disabled, but as detailed above, I installed the APK FROM the Xda forums and it works perfectly now with volte / WiFi calling.
    #41
    mirheldt likes this.
  2. A1560617887035
    Cupcake Jun 15, 2019
    A1560617887035 , Jun 15, 2019 :
    Can confirm that updated log kit worked here as well. I'm in Norway and I have two providers, one which supports this device and one that doesn't. Now working on Telenor here. Thanks
    #42
    justwondering likes this.
  3. Swejuggalo
    Lollipop Jun 21, 2019
    Swejuggalo , Jun 21, 2019 :
    Only used the apk and put the VoLTE and VoWiFi switches on? On Swedish Telenor and that did nothing...
    #43
  4. A1560617887035
    Cupcake Jun 21, 2019
    A1560617887035 , Jun 21, 2019 :
    Installed the apk and switched both on in the menu described earlier(restarted for each switch). I have telenor and telia, Telenor being sim 1.
    You can also double check the settings under WiFi & Internet in settings, you might have to switch those on as well.
    #44
  5. Swejuggalo
    Really odd... I got Telia verified as working by other users (probably even without the apk). But nothing on Telenor
    #45
  6. A1560617887035
    Yeah, that was my case. I had VoLTE on telia sim but not Telenor. Someone at Telenor told me it might be because the device is not yet supported by them, but everyone else supports it and sells it.
    Just to verify, you used this menu after installing apk? "*#800# --> oneplus Logkit --> Function Switch."
    #46
  7. Swejuggalo
    Yepp. Still no luck with Telenor. The switches is enabled and nothing is happening
    #47
  8. A1560617887035
    Hmm.. Weird. It might take a little while, but not hours. Could try restarting again just to try it, otherwise I don't know.
    The weird thing is that VoWiFi only worked for an hour on Telenor.
    I also wrote to Telenor encouraging them to support the device.
    #48
  9. Swejuggalo
    I started a post on Swedroid to list all the supported carriers and encurage other to ask and nag on carriers that do not. So far not looking good
    #49
  10. TobyK
    Donut Jun 30, 2019
    TobyK , Jun 30, 2019 :
    I had the same issue with Vodafone germany. After the workaround provided i am able to use WiFi caling but still having some issues with losing the wificalling Symbol
    #50
  11. zihaf17
    Gingerbread Jul 16, 2019
    zihaf17 , Jul 16, 2019 :
    im using gm1910 , volte icon not appear but during call it indicate "HD"..is that volte?
    #51
  12. L1537479603698
    Eclair Jul 24, 2019
    L1537479603698 , Jul 24, 2019 :
    No OnePlus fix? The informartic function * #801 # is not working. So we can not do the PDC scheme
    After the update 9.5.10 does not work the command * #801 # Unable to enable port for use of the PDC
    #52
  13. mariusmuntensky
    Froyo Aug 7, 2019
    mariusmuntensky , Aug 7, 2019 :
    Wrong! the carrier has nothing to do with supporting a specific phone, in most regions outside US! Most carriers do not have a whitelist, so any phone that has those options visible can connect. It has been proven by those that rooted their phones, and modified a file in android etc folder, to make those switches visible, and it worked.
    #53
  14. mariusmuntensky
    Froyo Aug 7, 2019
    working on 7 with Orange romania. after installing the updated apk, *#800#, activated the switches and rebooted, then in sim 1 settings, just enabled them and voila!
    #54
  15. manimaarans
    Honeycomb Aug 7, 2019
    manimaarans , Aug 7, 2019 :
    so I got this by observation . I had volte available for one of my carrier (jio) but for Airtel I got recently on my OnePlus 3. But for my roommate, it was available from a long time. when I enquired in carrier service center , I was told to contact the carrier customer support to enable it in my region for my model.
    also can you through this conversation
    #55
  16. manimaarans
    https://forums.oneplus.com/threads/airtel-volte-is-not-working-in-oneplus-3t.769411/
    it was discussed in the above link
    #56
  17. G_Sorin_Sleam_YmjJ
    Cupcake Oct 6, 2019
    G_Sorin_Sleam_YmjJ , Oct 6, 2019 :
    I'm on DIGI here in Romania, I just called them and apparently they cannot add the VoLTE and VoWIFI option, even if I enabled them for my OnePlus 7 Pro, the reason they gave me, is : "because it is not enabled on this model". I have mentioned that I manually enabled it, if they can add it to the list, but they said they cannot. So no luck for now.
    #57
  18. ouyamaster
    Honeycomb Nov 15, 2019
  19. P1572549808206
    Cupcake Jan 7, 2020
    P1572549808206 , Jan 7, 2020 :
    It depends on what software you are using. If you have in your software build gmaa then you will have to do the onepluslogkit then dialer *#800# and enable in function switch. Then head to networks-yor sim-then your sim card slot and should be their. If you have gmba which is Europe software build it is already activated. No need to do any of those. However it is also still up to your carrier and to whitelist as well. I have the gm10 China and can switch either builds.
    #59
  20. KarthiKeyan.R
    Cupcake Jan 8, 2020
    KarthiKeyan.R , Jan 8, 2020 :
    Go to settings -> WiFi and Internet -> sim & network -> and select sim1 or sim2 u will find the volte and vowifi switch inside
    #60
