volte not showing up
  1. dhawal.d7 Gingerbread Jun 23, 2019
    dhawal.d7, Jun 23, 2019 :
    I have a oneplus 7 pro and i am on vodafone network. The volte is enabled in settings but still there is no icon of volte in the status bar. Anyone knows how to get it?
  2. Killing Intent Froyo Jun 23, 2019
    dhawal.d7 likes this.
  3. dhawal.d7 Gingerbread Jun 23, 2019
  4. PARANOIA Cupcake Jun 23, 2019
  5. dhawal.d7 Gingerbread Jun 23, 2019
  6. Ajith V S Froyo Jun 23, 2019
    Ajith V S, Jun 23, 2019 :
    Are you from India and from which circle?
    Here after Vodafone and Idea merger customers are facing lot of issues. I had been using Idea VoLTE in last 6 months and from past 3 weeks VoLTE is not working especially in one district in here. Their merging finished in that district only. Their technical team is very poor and they are not accepting this is not working even though too many customers are facing this issue.
  7. dhawal.d7 Gingerbread Jun 23, 2019
    Yes bro i am from India. I am from maharashtra brother and same issue with me i am not getting volte on both vodafone and idea in my oneplus 7 pro. But my sister's redmi note 5 pro is showing volte on both vodafone and idea.
  8. Ajith V S Froyo Jun 23, 2019
    Oh ok. I am from Kerala. Are you sure the merging finished in your state?
    I tried my Idea sim on redmi note 5 pro but that didn't work. CC said to change my sim the issue is with my sim on the next moment I did it and got the same result.
    Tried Idea sim on iPhone, Honor, Oneplus and redmi on my district go the same result.
    One of my friend in another district on his OP phone Idea VoLTE is working because this merging not yet started there.
    Let's call your CC and make some chaos then only they will look into it. My good feeling this is the issue with Idea/Vodafone.
  9. dhawal.d7 Gingerbread Jun 23, 2019
    Yes the merger is finished in our state. Surely I'll contact the customer service regarding this because my sister's redmi note 5 pro and a realme 2 pro both are showing volte on both idea and vodafone but my phone is not showing volte on either of them.
  10. Ajith V S Froyo Jun 23, 2019
    So cool. I have just confirmed this issue with other OP customer also and across the country :). I am using Op6.
    My sister phone also not showing Idea VoLTE and it was there before.
    Start fighting. Good luck :)
  11. Killing Intent Froyo Jun 23, 2019
    Killing Intent, Jun 23, 2019 :
    It's the case with every OP7 Pro device. You need the log kit app from the link I shared with you. Once you download and install and follow the instructions it'll have the options like this.
  12. dhawal.d7 Gingerbread Jun 23, 2019
    Okk bro I'll try it. Thank you for the help.
  13. Ajith V S Froyo Jun 23, 2019
    This is for the case if enable VoLTE option is not there right?
    Tried this in my OP6 device didn't work.
  14. Killing Intent Froyo Jun 23, 2019
    I mean, on my 7 pro I had the VoLTE enabled under enhanced communications but it still wasn't active. It only got activated once I did the things from log kit. I'm not entirely sure about OP6 as Airtel VoLTE worked flawlessly on my OP6.
  15. Killing Intent Froyo Jun 23, 2019
    Not a problem. Do let me know if it worked for you.
  16. Ajith V S Froyo Jun 23, 2019
    Ok. If you have Idea sim could you please try that on OP6?
    You are from which circle? & what about Idea-voda merger in there?
  17. Killing Intent Froyo Jun 23, 2019
    I have neither Idea or Vodafone SIM to test it out. Also, I sold my OP6 for 7 Pro.
  18. Ajith V S Froyo Jun 23, 2019
    Wonderful. :)
  19. bpwest80 KitKat Jun 23, 2019
    bpwest80, Jun 23, 2019 :
    I tried the above instructions but it only works for a little while. My issue is VoWiFi won't show up even when I'm on WiFi, it stays on VoLTE.
  20. Ajith V S Froyo Jun 26, 2019
    Vishal Mathew likes this.
