4
VOLTE not working on 3.5.5 update for OP2
Has the VOLTE option enabled after upgrading to 3.5.6 by downgrading?
Poll closed Jan 24, 2017.
  1. Yes
    0 vote(s)
    0.0%
  2. No
    100.0%
  3. Software Crashed
    0 vote(s)
    0.0%
  4. Phone Keeps Restarting
    0 vote(s)
    0.0%
  1. Bibin Alexander
    Froyo Dec 24, 2016
    Bibin Alexander , Dec 24, 2016 :
    Hi folks,
    Don't know if this has happened to you. But suddenly after the continuous network drop issue the VOLTE feature is not working for the new update. I am using Jio (Slot 1) and Vodafone (Slot 2). While if you try enabling Jio as a standalone sim the 4G works fine but there's no VOLTE option available even if you try enabling the option.
    Let me know if you find a solution or have any solution for this.
  2. F_Vikas_Kawaliya_yqNA
    Eclair Dec 24, 2016
  3. Rahul Naharjain
    Cupcake Dec 24, 2016
    Rahul Naharjain , Dec 24, 2016 :
    Hello All This is So Annoying PLZ Guys Help me Out From this Thing From 2hrs I'm Charging But The Phone is Nt Charging At All For every Few Mins Network Drops Fed up with ths Plz Give me A Temporary Soln Plz
    praveenji and G_Rohith_R_ljtT like this.
  4. chetankrishna
    chetankrishna , Dec 24, 2016 :
    Network keeps dropping on either Jio or Airtel. Don't know why the update is doing this, have restarted my OP2 but same the issue continues.
    G_Rohith_R_ljtT and dayal_k like this.
  5. ishank007
  6. siri7113
  7. ramateja.g
    ramateja.g , Dec 24, 2016 :
    it works fine when on WiFi. no network drops. And also when I switch off mobile data. network seemed more stable. please try that out and update us..
  8. Bibin Alexander
    Froyo Dec 26, 2016
    Bibin Alexander , Dec 26, 2016 :
    Not working. The problem is apart from call drop there's no VOLTE option, this means the VOLTE option has been disabled due to the frequent call drop.
  9. F2FS
    Cupcake Dec 27, 2016
  10. G_Aritra_M_MiSi
  11. Greatbalaji
  12. pavantfs08413
    pavantfs08413 , Dec 27, 2016 :
    I'm also facing the issue of quick battery down.. my battery is now getting emptied in 3.5 hrs
  13. Vijayyaka
    Donut Dec 27, 2016
  14. Bibin Alexander
    Froyo Dec 27, 2016
    Bibin Alexander , Dec 27, 2016 :
    Have written to the One Plus Guys on Twitter and Facebook, but have not got any response yet. This is so much inconvenience. Guys, if you get any solution, pls do share. @Tony L. Request you to pls look into this issue immediately.
  15. ponnilavan
    ponnilavan , Dec 27, 2016 :
    First I also had that issue, after I change every thing to jio, volte enabled
    Change
    call-jio
    Message-jio
    Cellular data-jio
    Every thing to jio, volte may enable
  16. DotNetCore
    Gingerbread Dec 27, 2016
    DotNetCore , Dec 27, 2016 :
    Same here. After I updated to OOS 3.5.5 for 2 days I could be able to enable VoLTE. But from today its not enabling. Not sure if the OnePlus team has disabled it?
    Please help.........
  17. Ambatti
    Eclair Dec 27, 2016
    Ambatti , Dec 27, 2016 :
    This was my case too. After resetting network, things have improved and hoping to get updates at the earliest for battery and network issues.
  18. Sharma_Rohan
    Sharma_Rohan , Dec 27, 2016 :
    Take all the sim cards out. perform a restart. Reset network settings. Delete all APN settings also. Switch of the device, re install the sim cards, set the APN settings, select volte for sim 1 with Jio and restart the device. Hopefully it will work.
  19. Bibin Alexander
    Froyo Dec 27, 2016
    Will try doing this. Meanwhile, this is what One Plus team responded when I had raised this issue.
  20. F_R_Anil_Kumar_hfeF
    F_R_Anil_Kumar_hfeF , Dec 27, 2016 :
    I am facing the same problem. For the 1st time I upgraded the software after tat I am facing battery problem it takes 7hrs to get fully charged there is no fast charging in this. And 2nd time when i upgraded the software the other problem occurred tat is network dropping getting irritated by seeing these issues..
    Please resolve this issue as soon as possible.
