VOLTE option missing, Phone gets too much of heat
  1. ketan.4
    Eclair Apr 15, 2017
  2. dinesh_vd
    Cupcake Apr 15, 2017
    dinesh_vd , Apr 15, 2017 :
    after update of 3.5.8 i also got the same issue...i insert the JIO sim in slot 2 and switch off the phone after 24 hrs it will get resovled..
    just in case see if you have activate the volte enabled option or not..if its off then on it and also make default net preference of JIO sim..
  3. arjunbapa24
  4. Akash@02
    Cupcake Apr 16, 2017
    Akash@02 , Apr 16, 2017 :
    same here ... jio sim not working and tried all but calling is disabled after the update due to option for enhanced communication and VoLTE is not present.
  5. kingudit
    kingudit , Apr 16, 2017 :
    Download the official zip file of the firmware version 3.5.8 from the Oneplus site clear cache and flash it hope it gonna work... Even i am using it no issues yet... VOLTE wprks fine...
  6. Ravi BINAVAT
    Ice Cream Sandwich Apr 16, 2017
    Ravi BINAVAT , Apr 16, 2017 :
    I am facing same problem.... update again or make network settings for volte support, thanx
  7. Manoj kumar manu
  8. G_Santosh_Kothari_IOxB
    G_Santosh_Kothari_IOxB , Apr 16, 2017 :
    After flashing 3.5.6 upon 3.5.8 will format phone?
  9. yohannvt
    yohannvt , Apr 16, 2017 :
    I was also having same issue that the VoLTE on my phone was not working... I first reset my phone & then restarted it.. Now my phone is working fine..
  10. tanishqparkhe
    Donut Apr 16, 2017
  11. ketan.4
    Eclair Apr 16, 2017
    ketan.4 , Apr 16, 2017 :
    no
  12. rupam1987
    rupam1987 , Apr 16, 2017 :
    Try using the safe mode.... Go into safe mode and u will see volte is working.... Then restart your phone...
    It worked for me perfectly...
  13. rkmaheshwari
    Cupcake Jun 13, 2017
  14. Sagar_SR7
    Cupcake Jun 14, 2017
    Sagar_SR7 , Jun 14, 2017 :
    Hey,
    It is regarding the issue being faced with my oneplus 2 all of a sudden the (1) hardware buttons stopped working and even the (2)VOLTE isn't working and always there is a problem with Jio network everytime is reboot the phone a message pops up saying unable to detect Sim card!!!
    There are few bug fixes need to be done @OnePlus I hope you satisfy your customers
    I hope there is an update for atleast these bug fixes if not for the Nougat update!!
  15. Sagar_SR7
  16. Aru09022000
    Eclair Jun 14, 2017
  17. Guri@1+
    Donut Jun 14, 2017
    Guri@1+ , Jun 14, 2017 :
    aah tht heating issue .. it really difficult to hold device even on average daily usage
