volume bar not going off soon
  1. V1515562118265 Eclair May 18, 2019
    V1515562118265, May 18, 2019 :
    when I press a volume key , the volume bar shows up and remain showing about 18 seconds then go off , when I talk about this to a oneplus service centre guy he said that this is a bug and it's fix when you format your device. why all fix depends on format,,is there any other option to fix it..??
  2. Sharry7 Ice Cream Sandwich May 18, 2019
    Sharry7, May 18, 2019 :
    I think he's right. A reset will do. Sometimes unexpected bugs arrive.
    You can make a full backup using Oneplus Switch app. From call logs to applications, everything can be backed up.
  3. V1515562118265 Eclair May 18, 2019
    is there any other way to fix it...??
    it's happened on my op 5 device also..
  4. Sharry7 Ice Cream Sandwich May 19, 2019
    Sharry7, May 19, 2019 :
    I'm afraid not.
    BTW how did you brought never settle logo on the oneplus widget with your mobile data on? Have you disabled the weather app?
  5. V1515562118265 Eclair May 19, 2019
    V1515562118265, May 19, 2019 :
    yup.. I disabled the weather app
