volume button change media sound
  1. G_Abdalrhman_Al-Dayel_bz Eclair Mar 15, 2017
    shazbots likes this.
  2. G_Sơn_Tùng_Huỳnh_vEy Eclair Mar 15, 2017
    G_Sơn_Tùng_Huỳnh_vEy, Mar 15, 2017 :
    actually, the volume buttons change both media and ringer volume according to context on the screen. If it's idle, it will change the ringer volume by default. If it's playing something, it will change media volume.
    Hope this help.
    Justin709 likes this.
  3. G_Abdalrhman_Al-Dayel_bz Eclair Mar 15, 2017
    Leoxur likes this.
  4. Javin Bhalla Donut Mar 15, 2017
  5. MichaelCapote Cupcake Mar 15, 2017
  6. Bartnl Lollipop Mar 15, 2017
    Bartnl, Mar 15, 2017 :
    press the volume button and the notification menu of the ringer volume appears, press the pointing down arrow and you will have the complete range of volume settings.
  7. Tilaf Cupcake Apr 26, 2017
    Tilaf, Apr 26, 2017 :
    yeah I have the same "problem".
    I'm in silence mode everytime and when I want to control volume is only for media volume. (and change ringtone volume do nothing in silence mode because it's locked...)
    Apple phone have a parameter to lock used of volume button for media maybe is it possible to have something similar on Oxygen ?
  8. nielsfeyaerts Cupcake Jun 4, 2017
    nielsfeyaerts, Jun 4, 2017 :
    Anyone found a fix for this? I've been having the same problem lately. My Oneplus 3t is always on silent mode, and before, I could change the volume when media played by just pressing my volume buttons. Now though, it changes my ringing volume.
    Whenever I reboot my phone, it fixes itself for a while, but then it changes back.
    mohawahba likes this.
  9. mohawahba Gingerbread Jun 5, 2017
    mohawahba, Jun 5, 2017 :
    it's because Facebook msgr or viber is taking control of the phone as if a call still ongoing. immediate solution is either to clear all apps from recent or manually close voip apps like fb msngr viber etc. used to happen on nexus with me as well so it's not a bug from op.
    on the other hand, ppl saying it's a bug the volume button, no it's not a bug. just use the drop menu when the ringer appear
  10. F_Homa_Jafari_OXAv Cupcake Jun 5, 2017
    F_Homa_Jafari_OXAv, Jun 5, 2017 :
    r
  11. F_Homa_Jafari_OXAv Cupcake Jun 5, 2017
  12. F_Homa_Jafari_OXAv Cupcake Jun 5, 2017
  13. F_Diganta_Koner_WIXu Jelly Bean Jun 5, 2017
    F_Diganta_Koner_WIXu, Jun 5, 2017 :
    This process is the only one which will help you.
  14. SimonDarway Cupcake Jun 29, 2017
    SimonDarway, Jun 29, 2017 :
    I use Rocker Locker, free on the Play Store, to do this. It force the volume buttons action always to media volume control instead to ringer volume.
    grulong likes this.
  15. Benimasiiiii Cupcake Jun 29, 2017
    Benimasiiiii, Jun 29, 2017 :
    You can install an application called Rocket Locker to always control the media volume with volume buttons.
    E1510854199402 and grulong like this.
  16. Alooof Donut Jul 20, 2017
    Alooof, Jul 20, 2017 :
    I have the same bug. It used to adapt to music playing, now the buttons always control the ringer.
  17. grulong Eclair Jul 25, 2017
    grulong, Jul 25, 2017 :
    Oxygen OS should feature the volume rocker customization. Really annoying having to click that drop down arrow every time before I start the video to adjust the listening experience.
  18. Lucasizq Cupcake Jan 2, 2018
    Lucasizq, Jan 2, 2018 :
    Hi everybody, just wanted to let you guys know that this feature works on samsung phones, and STOCK android phones. I know it's not much help to the problem, but i hope this helps clear up some stuff!
  19. shazbots Cupcake Mar 19, 2018
  20. Leoxur Donut Jan 11, 2019
