12
Volume buttons only control media
  1. BluGuy
    Donut Nov 6, 2018
    BluGuy , Nov 6, 2018 :
    Noticed today that when you press the volume buttons it will only control media volume, even when no media is playing. OnePlus customer support said that it was a software decision. Am I the only one who thinks the Volume buttons should be able to adjust the Ring volume if no media is being played? I know I could do that on my 3T.
  2. UncleTug
    Cupcake Nov 6, 2018
    UncleTug , Nov 6, 2018 :
    I agree. If no media playback is present, it doesn't make much sense for media volume to be the primary volume button control.
  3. Big Cam
    Honeycomb Nov 6, 2018
    Big Cam , Nov 6, 2018 :
    Yes, there must be a workaround, regular Android pie allows you to select ringer once you've started pressing up or down.
    I don't understand why oneplus would have changed this.
    J1572910900599, jesalpha and SZQ75 like this.
  4. pdxtechy
    Froyo Nov 7, 2018
  5. Hoots2
    Gingerbread Nov 7, 2018
    SZQ75 likes this.
  6. G_Aleron_Toth_NfuR
    Eclair Nov 8, 2018
    G_Aleron_Toth_NfuR , Nov 8, 2018 :
    I'm glad they have it this way at OnePlus. I always changed the volume accidentally and I wouldn't change it often. I'm fine with entering the settings for this.
    shogun168 likes this.
  7. lweisenbacher
    Donut Nov 8, 2018
    lweisenbacher , Nov 8, 2018 :
    I agree! The volume buttons/selection is terrible compared to my 3t! I can't stand how the slider works now! It's so frustrating!
    J1572910900599 likes this.
  8. shubhamsubhash
    Froyo Nov 10, 2018
  9. hotsauce
    Lollipop Nov 10, 2018
    hotsauce , Nov 10, 2018 :
    So... you're fine with having your ringer ring every time you change ringer volume? This feature is annoying and oneplus should have docked the ringer volume slider to the audio volume slider.
    Dark_Matrix_Guru and jesalpha like this.
  10. SuperA187
    Froyo Nov 10, 2018
  11. F_Akash_Patel_kFYd
    Cupcake Jan 28, 2019
    F_Akash_Patel_kFYd , Jan 28, 2019 :
    Noticed today that when you press the volume buttons in oneplus 5t will only control media volume, even when no media is playing. OnePlus customer support said that it was a software decision. Am I the only one who thinks the Volume buttons should be able to adjust the Ring volume if no media is being played?
    J1572910900599 and Ceasarnegi like this.
  12. Intruder71
    Lollipop Jan 28, 2019
    Intruder71 , Jan 28, 2019 :
    It's a Google desison go complain to them..
  13. D...B....N...in
    Cupcake Mar 22, 2019
    D...B....N...in , Mar 22, 2019 :
    Is there a way to change the volune control button to actually control phone volume rather than media volume?
  14. Kytharsis
    Nougat Mar 22, 2019
    Kytharsis , Mar 22, 2019 :
    Literally read the post above yours.
  15. D...B....N...in
    Cupcake Mar 24, 2019
    D...B....N...in , Mar 24, 2019 :
    I am also trying to find a way. How can they give such a crap feature which completely wastes the use of volume button. Noone plays media 24/7
  16. Kytharsis
    Nougat Mar 24, 2019
    Kytharsis , Mar 24, 2019 :
    Blame Google. It's their decision.
    Deactivated User likes this.
  17. Dark_Matrix_Guru
    Ice Cream Sandwich Mar 24, 2019
    Dark_Matrix_Guru , Mar 24, 2019 :
    How do you change the buttons to map ring volume and not media?
  18. SuperA187
    Froyo Mar 24, 2019
    SuperA187 , Mar 24, 2019 :
    There is a toggle in the app. It says 'Default to ring volume'.
    Dark_Matrix_Guru likes this.
  19. Dark_Matrix_Guru
  20. SuperA187
    Froyo Mar 24, 2019
    Removing it completely might be a rooted thing. I didn't root my device. It's smart enough, for me, to know which of the two volumes I want adjusted depending on the screen I'm on except on Google Duo. I need to turn it off at that point.
