2
Volume change without using buttons via OnePlus 7 Pro
  1. #1
  2. Y1567729079379
    Cupcake Oct 6, 2019
  3. m.tariq
    Donut Oct 6, 2019
  4. Y1567729079379
    Cupcake Oct 6, 2019
    E1569123013705 likes this.
  5. Shivam Bhatia , via OnePlus 7 Pro , Oct 6, 2019 :
    This option is different, what i want is that one plus should hive this option in the notification menu.
  6. Obstinate
    Froyo Oct 6, 2019
    Obstinate , Oct 6, 2019 :
    it doesn't matter what you want. what matter is the features that benefit all.
    xnutzii, pgrey and Auristic like this.
  7. Shivam Bhatia , via OnePlus 7 Pro , Oct 6, 2019 :
    This feature will benefit all because it will allow us to use the volume buttons less and hence the buttons will have a longer life span.
  8. pgrey
    Ice Cream Sandwich Oct 6, 2019
    pgrey , Oct 6, 2019 :
    @Shivam Bhatia Have you ever had one fail?
    I've "heard of it", on low-budget devices (obviously, with lower-quality buttons, etc), but on higher-end phones, I think this is pretty darn rare.
    Not sayin' it can't happen, there are always a few "manufacturer defects" out there, but the likelihood of it happening, due to "regular use" is very low...
    There are apps out there, too, I remember hearing about one called "chop cut", or similar, that a lot of people were using, for awhile.
    DTTW/lock-sleep is awesome, but I'm not sure I share the same "feeling about the need", for the drop-down model, to @Obstinate's comment...
