Volume fluctuations via headphones
  1. L1545991673634 Cupcake Jun 7, 2019
    L1545991673634, Jun 7, 2019 :
    I am experiencing volume fluctuations via headphones in my OP6T a few months back maybe from April Update. are you guys finding it too ???
    it's like volume decreases or increases while listening to music though the volume bar remains at 100% .
    It's like SDVC in 4wheelers.
  2. Kush_Ghuraiya Eclair Jun 7, 2019
  3. antonio1389 Cupcake Jun 7, 2019
    antonio1389, Jun 7, 2019 :
    Do you have the audio tuner in sound settings on? I experimented that with that tuner on, try to dissable it
  4. L1545991673634 Cupcake Jun 8, 2019
    L1545991673634, Jun 8, 2019 :
    No. I use the stock Fingerprint sensor
  5. L1545991673634 Cupcake Jun 8, 2019
    Yes. I have the tuner ON.
    but before it was not like that. The volume didn't fluctuated.
  6. Kush_Ghuraiya Eclair Jun 8, 2019
    Kush_Ghuraiya, Jun 8, 2019 :
    only solution is to do format !
  7. L1545991673634 Cupcake Jun 8, 2019
    Oh... I saw others having the problem too.
    It started after the April update I guess. before it was not like that. It happens while playing music via Bluetooth too.
    drummingchef likes this.
  8. Kush_Ghuraiya Eclair Jun 8, 2019
    yeah i too had the same problem !
    got replaced my Sennheiser pxc 550 for that...still bug remained !
    last option i opted to go service centre !...
    they did a format and now all is okay
  9. L1545991673634 Cupcake Jun 12, 2019
    L1545991673634, Jun 12, 2019 :
    Don't want to format though... Let's wait for the next update and see.
  10. drummingchef Cupcake Jun 13, 2019
    L1545991673634 likes this.
  11. Muhsin_Sultan Ice Cream Sandwich Jun 13, 2019
    Muhsin_Sultan, Jun 13, 2019 :
    Use OnePlus switch app to backup then format. Trust me it does a perfect job. You will hardly notice It was formatted and reset.
