[Submitted] Volume gets stuck going up or down when accidentally hitting one of the volume button when unlocking
  1. jamstaa
    Cupcake Nov 21, 2018
    jamstaa , Nov 21, 2018 :
    Sometimes when unlocking the phone with the power button and also accidentally pressing one of the volume buttons the volume will 'get stuck' and either max out or mute. This can only be stopped by pressing one of the volume buttons again as if you try to tap away the volume slider in the UI it'll just re-appear again as if the volume button is being continually pressed.
    To reproduce, unlock the phone using the power button while simultaneously pressing the volume up or down buttons
  2. satan2986
    Cupcake Jun 30, 2019
    imarunprakash likes this.
  3. imarunprakash
    Donut May 11, 2020
    imarunprakash , May 11, 2020 :
    have u repaired it or not I'm also facing the same issue
  4. satan2986
    Cupcake May 11, 2020
