3
Volume issues on oneplus 6
  1. iamrasesh
    Cupcake May 26, 2018
    iamrasesh , May 26, 2018 :
    today I encountered this problem where I am pressing the volume button and the screen duly shows volume change however the volume of the media remains low.
    help!
  2. denisegrech
    Cupcake May 29, 2018
  3. bordy777
    Froyo May 29, 2018
    bordy777 , May 29, 2018 :
    Hi there, have been using oneplus 6 for quite some time and I noticed quite kow volume when I listen to audio like general speech using headohones. It is not that bad but average at best. I have seen here post about voltage in actual headphone jack being almost twice as low as oneolus 3t. Are you having any issue just like me with your oneplus?
    I mean the 3t sounded way better and i Donr even mention xiaomi in low budget segment thas has phenomenal headphone jack quality.
  4. karthikmohan_
    Froyo Jun 1, 2018
    Q1550000031629 likes this.
  5. F_Saju_Raveendran_JrZK
    Ice Cream Sandwich Jun 1, 2018
  6. monicaeffe
    Cupcake Jun 5, 2018
    monicaeffe , Jun 5, 2018 :
    Hello, I have a Oneplus 6 and the volume bar doesn't work I cannot turn it up, it says: ring volume at 0%. I don't have the DND option active - all the settings look fine. Does someone has the same issue? can someone help me with it?
  7. Y1527151126111
    Froyo Jun 5, 2018
  8. karthikmohan_
    Froyo Jun 5, 2018
  9. G_kevin_richardson_GwkH
    Eclair Jun 18, 2018
    G_kevin_richardson_GwkH , Jun 18, 2018 :
    I think the volume in headphones is fine. it all depends on the audio quality from the video you are watching. for instance I've noticed that the volume rocket can be super low on some videos and I can hear it fine but others I have to be darn near 60% loudness before it's even a whisper. I know this because when on YouTube some videos are excellent quality soundwise and others are poor. also when going on Google music & Amazon Music, all the audio there is really good. which means on Google music n Amazon Music my volume can be at ≈10% and be quite audible at work.
    So maybe it's the quality of the audio itself and not the OnePlus 6 ..... however on pure speaker sound you would be correct. I believe the volume rocket was setup for best audio out of headphones( wired and Bluetooth) so the speaker is just meh
  10. Senthil338
    Cupcake Oct 17, 2018
    Senthil338 , Oct 17, 2018 :
    I am facing the volume issue after latest software updates on One Plus 6. Video and Audio does not play a sound even volume button moved to 100%.
  11. P1539791450040
    P1539791450040 , Oct 17, 2018 :
    I m facing problem with the volume...after increasing the volume a no. of times it's not working can anyone help me on this??
  12. denisegrech
    denisegrech , Oct 17, 2018 :
    you checked the volume button on the right hand side too? just in case
  13. P1539791450040
    yes I checked it still it's not working
  14. Applephx
    Eclair Oct 17, 2018
    Applephx , Oct 17, 2018 :
    I had the same issue with media volume. Do not disturb mutes media volume. I think you can thank Google for this... maybe they are hiring some green developers.
    Have you tried making sure "do not disturb" mode is disabled?
  15. P1539791450040
    Cupcake Oct 18, 2018
    P1539791450040 , Oct 18, 2018 :
    yes do not disturb option is in disabled mode.I have tried everything but it is still not working.
  16. dambukutty
    dambukutty , Oct 18, 2018 :
    Same problem here . The phone is in vibration mode for the past two weeks. Ringtone volume up is not working at all . Cannot slide and increase the volume..
  17. denisegrech
    denisegrech , Oct 18, 2018 :
    on the right hand side, there is a slide button, ring - vibration - silent. are you sure it is on ring?
  18. dambukutty
  19. dambukutty
    the ring volume sliding is not possible.. nothing can be done. no modifications cannot be done.
  20. denisegrech
    but you are in settings there. what I am saying that you physically slide the button on your phone - on the right hand side - not amend settings.
