Volume key is not working properly
  1. harishkumar101
    Cupcake Jul 16, 2019
    harishkumar101 , Jul 16, 2019 :
    After the recent update volume key is not working properly ....even after pressing down or up there is no change in volume.
    Volume only changes after going to Sound settings under Settings
    Q1564812105333 likes this.
  2. Muhsin_Sultan
    Ice Cream Sandwich Jul 16, 2019
    Muhsin_Sultan , Jul 16, 2019 :
    Use OnePlus care app or any other 3rd party one to test the hardware/software buttons
  3. Q1564812105333
    Cupcake Nov 22, 2019
    Q1564812105333 , via OnePlus 7 Pro , Nov 22, 2019 :
    i am having same issue with my one plus 7pro
    volume key is doesn't make any change while call is running even the ringing tone volume doesn't make any difference if it is kept at maximum or minimum.
  4. Waveform Modifier
    Marshmallow Nov 22, 2019
    Waveform Modifier , Nov 22, 2019 :
    1. Wrong forum
    2. Contact OnePlus support for hardware support. This is a user community forum and not tech support.
    Malg220 likes this.
