Volume level changes only on every second keypress via OnePlus 7T
  1. mchriss
    Cupcake May 4, 2021 at 6:46 PM
    mchriss , via OnePlus 7T , May 4, 2021 at 6:46 PM :
    Hi! I've had my OnePlus 7T for more than a year, and I've noticed right from the day of getting it that the volume level changes only after every second level. I thought it's just a bug that will be fixed later, or that my headphones make it behave like this. But since then I've got the Android 11 update and I switched headphones too, and the issue is still present (it's more noticeable with headphones, but it seems to do the same on speaker too). It's not a hardware issue, every press is registered, and it doesn't depend on what app I use.
    Does anyone else have this issue?
    Is there a fix for it?
  2. J4t1np4r3kh
    OnePlus Accessory Tester May 5, 2021 at 3:57 PM
  3. mchriss
    Cupcake May 6, 2021 at 11:17 AM
    mchriss , via OnePlus 7T , May 6, 2021 at 11:17 AM :
    There are (or should be) 30 different volume levels, but for me there are only 15. 1 and 2 are the same loudness, 3 and 4 too, and so on
  4. J4t1np4r3kh
    OnePlus Accessory Tester May 6, 2021 at 10:01 PM
    J4t1np4r3kh , May 6, 2021 at 10:01 PM :
    Is it that they're the same, or audibly it sounds the same?
  5. mchriss
    Cupcake May 6, 2021 at 10:02 PM
