Volume Limit via OnePlus 9
  1. nicolasberlin888
    Froyo Sep 18, 2021
    nicolasberlin888 , via OnePlus 9 , Sep 18, 2021 :
    Hi there ,
    Not sure since when, but now when i want to raise the volume I'm always confronted with the attached notification :( I need to accept and only then I can raise the volume again.
    How can I disable this notification forever?
  2. Aaron2017
    Lollipop Sep 18, 2021
    Best Answer
    Aaron2017 , Sep 18, 2021 :
    If you go into the developer options and turn on disable absolute volume, the warning should not show up again.
    McJader, rHITkM., Caomhin and 5 others like this.
  3. nicolasberlin888
    Froyo Sep 21, 2021
    nicolasberlin888 , via OnePlus 9 , Sep 21, 2021 :
    Hi, i thought this helped , but I had to turn "disable absolute volume" off again because this made the sound through my headphones very very low.
  4. Aaron2017
    Lollipop Sep 21, 2021
    Aaron2017 , Sep 21, 2021 :
    Oh, right. Well, i found this older thread on XDA, don't know if it i'll work and it is pretty technical, so maybe not that easy, but i'll leave it here anyway.
    https://www.xda-developers.com/how-to-automatically-disable-the-high-volume-warning-without-root/
    Other than that i don't there's anything else to do about it, it's there because of regulations, or so i've read. For me it doesn't happen all that often, i think it repeats itself after a certain amount of listening time.
    nicolasberlin888 likes this.
