3
Volume notification bar popping up randomly via OnePlus 6T Mirror Black
  1. SundeepEliza , via OnePlus 6T Mirror Black , Nov 20, 2019 :
    After the OOS 10.0 Update, the volume notification bar appears without pressing any buttons. I searched the whole forum and I don't think others have an issue like this. Is there any solution for this? Please help.
  2. Auxqii
    Honeycomb Nov 21, 2019
    Auxqii , via OnePlus 6T Mirror Black , Nov 21, 2019 :
    I have that issue sometimes but only when I connect my headphones with the Jack to Type-C adapter. It seems there is a connectivity issue sometimes with it.
    Never had this issue anytime except that scenario.
  3. B1577443304012
    Cupcake Jul 27, 2020
    B1577443304012 , Jul 27, 2020 :
    I am having the same issue with my bluetooth headphones. Whenever there is any sound, the volume bar pops up on the screen. Any solution?
  4. B1577443304012
    I am using a OP6
  5. Auxqii
    Honeycomb Jul 28, 2020
    Auxqii , via OnePlus 6T Mirror Black , Jul 28, 2020 :
    This is a last year's post and the bug hasn't occurred since then on my phone. Perhaps you should contact Customer Support and send your phone for inspection. If it was an issue related to the firmware, it should have been solved through all these updates since then.
    Have a nice day.
  6. B1577443304012
    Cupcake Jul 28, 2020
  7. Auxqii
    Honeycomb Jul 31, 2020
    Auxqii , via OnePlus 6T Mirror Black , Jul 31, 2020 :
    I think so. I haven't encountered this issue months now. I also took a toothpick and cleaned the slide bar, alot of dust came out concerning the size of the slide area.
  8. B1577443304012
    Cupcake Jul 31, 2020
    B1577443304012 , Jul 31, 2020 :
    Hmm. I hope it resolves with an update
  9. Auxqii
  10. B1577443304012
    Thanks for the tip, but given the issue occurs without me handling the phone, I think it's more of a software issue. I'll give it a go nonetheless!
  11. I1597902569720
    Cupcake Dec 8, 2020
    I1597902569720 , via OnePlus 8 Pro , Dec 8, 2020 :
    I am facing the same issue on my one plus 8 pro. The volume bar disappear only afyer restart. I have to restart mt mobile again and again. Pls convey any solution ...
