9
Volume too low at even 50%, OnePlus 8 Pro via OnePlus 8 Pro
  1. Yash_24
    Donut Jun 22, 2020
    Yash_24 , via OnePlus 8 Pro , Jun 22, 2020 :
    The title says it all, OnePlus 8 Pro volume is very very low at 50% much like 10%.
    so many bugs!! ahh
    When will a new update come for all this issues especially the display issues?
  2. #2
  3. venkar13
    Froyo Jun 24, 2020
    bharathkumaravatar and Yash_24 like this.
  4. Ujjwalprashar
    Community Bug Hunter Jun 25, 2020
  5. Ujjwalprashar
    Ujjwalprashar , via OnePlus 7 , Jun 25, 2020 :
    I dont claim about any percentages but YES the volume is low especially since they 'fixed' volume too loyd on lowest setting. In normal environment you can't hear anything clearly lower settings and in the lowest it's inaudible even if you put it right next to your ear.
    I even submitted feedback with log but no improvement.
  6. Ozymandias_Osiris
    Honeycomb Jun 25, 2020
  7. Ujjwalprashar
    G1599453574276 likes this.
  8. Ozymandias_Osiris
  9. Ujjwalprashar
    Bro speak for yourself... Don't think the world revolves around you only and you're the centre of attraction
  10. Ujjwalprashar
    It's because of you blind fanboys who are so ignorant to the visible flaws in the product just because of their blind 'loyalty' and aren't willing to accept that there is a problem especially if it them that aren't facing it
    Steven dawe and Nipun18 like this.
  11. Dr.No.pt
    Froyo Jun 25, 2020
  12. Nipun18
    Cupcake Jul 10, 2020
    Nipun18 , via OnePlus 8 Pro , Jul 10, 2020 :
    Facing same issue and it is so annoying.
    Even the facing the display issues and heating issues too.
    It feels very bad when you pay such a premium price.
  13. RITHIKRAJA
    Eclair Aug 16, 2020
  14. Cheezburgers
    Honeycomb Aug 16, 2020
    Cheezburgers , Aug 16, 2020 :
    personally, ive felt like the speakers dont increase at a constant rate like they should. its fine for me at low levels, but i feel like it gets a lot louder than expected starting at 70%ish
    RITHIKRAJA likes this.
  15. B1542341498924
    Eclair Aug 25, 2020
    B1542341498924 , Aug 25, 2020 :
    Noticed it too. Before doing a clean install of OOS, audio used to be loud and clear even on lower volume levels. After doing a clean install of 10.5.12 and then an incremental update to latest 10.5.13, you now need to crank the volume level super high to hear anything even in a fairly quiet room.
    Jeez, first there's issues with 5ghz wifi if bluetooth's on, and now audio level problems. Hate the fact I might have to go with another brand of phone if these problems don't get addressed.
  16. bharathkumaravatar
    Gingerbread Dec 5, 2020
    bharathkumaravatar , via OnePlus 8 , Dec 5, 2020 :
    Hi,
    Bought a new OnePlus 8 two days ago.
    I've updated to latest OOS 11.0.2
    Even after that I found this stupid issue with speakers volume
    At 50% I can hear like it was giving me only 20% volume.
    I need to crank up the volume to 100% to watch YouTube.
    Is this only for some devices or all the OnePlus 8 and 8 pros are getting this?
    Did you get any kinda solution for this?
    Please do reply if you found any fix.
    Thank you.
  17. [email protected]@17 , via OnePlus 8 Pro , Dec 8, 2020 :
    The title says it all, OnePlus 8 Pro volume is very very low at 50% much like 10%. while playing media play back only the volume lower particularly the down side speaker volume is lower I have been noticed. if I kept to maximum volume the sound is louder but with in 50% of volume only its lower to hear compared with OnePlus 7 t.
    so many bugs!! ahh
    When will a new update come for all this issues especially the display issues? So fix this problem by update
    Steven dawe likes this.
  18. bharathkumaravatar
    Gingerbread Dec 8, 2020
    bharathkumaravatar , Dec 8, 2020 :
    are you also facing the same issue?
    which device you are using?
  19. bharathkumaravatar
    bharathkumaravatar , via OnePlus 8 , Dec 8, 2020 :
    Dude wrong group and I've also used OnePlus 7 and you are speaking from OnePlus 7 s perspective but it is like we OnePlus 8 and pro users are facing this issue.
    Check before commenting even in a website where the audio quality for mobiles tested posted that OnePlus 7 series has too loud when volume is low and OnePlus 8 series having too low when volume is too low.
    This is an issue for us and ur in the group and don't wrong him dude
    Get out from this thread noob.
    T1612643481508 likes this.
  20. T1612643481508
    Cupcake Feb 6, 2021
    T1612643481508 , Feb 6, 2021 :
    man i dont know what to say and i am depressed af its been 4 days since i bought this phone and i havent noticed this issue untill yesterday. the volume is too low. my heart just shattered into pieces after finding this out cuz this was my first phone my parents didnt allow me to have one untill i turned 18 and bought this phone with my own money 62000 bucks (in my country) by the way. Can someone tell me what should i do now
