3
[Submitted] Volume up + Power button gives "calls and notifications will vibrate" message
  1. NiranjanNair
    Cupcake Oct 19, 2020
    NiranjanNair , Oct 19, 2020 :
    Volume up + power button combo gives a "calls and notifications will vibrate" message. The phone isn't put into vibrate mode. But all calls and notifications make no sound. Volume toggle shows sound. To fix it have to toggle alert slider to vibrate and back to ring.
    Have seen this issue on the forums but since there was no resolution anywhere, I'm posting.
    edit: On Android 11 update the status bar doesn't show vibrate mode. But in quick settings you can see "phone on vibrate". and volume button shows call on vibrate.
  2. RoyDecoy
    Ice Cream Sandwich Oct 19, 2020
  3. NiranjanNair
    NiranjanNair , via OnePlus 8 , Oct 19, 2020 :
    If you google it, it's listed as an older Android feature. As it's listed under "if you have an older Android version". And the thing is I can't turn it off. Android 11 has the volume up and power button mapped to the power off screen if you have assistant on the power button. So it can't mean to have this mapped to it. On top of that it only happens on some phones, and not others. There's no way to switch it off. Nor is it mentioned anywhere.
  4. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member Oct 21, 2020
    Ghazala.Yasmeen , Oct 21, 2020 :
    We have made a note of this and our developer team is currently working on this. We will keep you posted regarding the further updates. We appreciate your support and patience in this regard.
    Regards,
    Ghazala
    G_Zachary_Hunt_qZBQ likes this.
  5. Lyman
    Eclair Oct 24, 2020
    Lyman , Oct 24, 2020 :
    I'm so glad this is finally acknowledged. I posted the same thing months ago and never got a response. It's so easy to accidentally press both buttons since they're level with reach other.
  6. janchix
    Cupcake Jan 19, 2021
    janchix , Jan 19, 2021 :
    I have the same issue on Nord. I had noticed that ocasionally the sound wasn't working. And also because of button placement I often take screenshots unintentionally. Only now I noticed the message "calls and notifications will vibrate". I am somewhat happy, that the sound does't turn off by itself, as I had presumed, but this "feature" should be removed or atleast switchable.
  7. Lyman
    Eclair Feb 3, 2021
    Lyman , Feb 3, 2021 :
    Hello. Any progress from the dev team?
  8. U1591726962083
    Cupcake Feb 4, 2021
    U1591726962083 , Feb 4, 2021 :
    If you have ADB installed on your computer and USB debugging enabled, you should be able to disable this with the command
    Code:
    adb shell settings put secure volume_hush_gesture 0
    . Hopefully OnePlus pushes an update to add a user-facing setting for this soon.
  9. janchix
    Cupcake Feb 7, 2021
    janchix , Feb 7, 2021 :
    This solved the issue. Thank you!
  10. G_Zachary_Hunt_qZBQ , via OnePlus 8 Pro , Feb 11, 2021 :
    Very helpful - thank you so much!
  11. D1615229111731
    Cupcake Mar 16, 2021
    D1615229111731 , via OnePlus 8 Pro , Mar 16, 2021 :
    Created an account just to say thanks for this. Was driving me crazy.
    SpacingSalvage likes this.
  12. H1619637062572
    Cupcake Apr 28, 2021
    H1619637062572 , Apr 28, 2021 :
  13. H1619637062572
    Are you KIDDING ME?
    This has been driving me absolutely insane for months and every internet forum says it just cant be done. And its just an adb settings change? And OF COURSE it just works right away without any fuss.
    Who are you, sir? Who are you?
    (tl;dr: thanks.)
  14. Dox I
    Cupcake Sep 12, 2021
    Dox I , Sep 12, 2021 :
    THIS ACTUALLY WORKED! I can no longer activate vibrate mode by pressing Vol.up & Pwr. AMAZING FIX!
