3
volume
  1. W1565083037884
    Eclair Dec 8, 2020
    W1565083037884 , Dec 8, 2020 :
    volume button is not working properly.
    previously if we keep the button pressed it either gradually increase or decrease depending upon the button pressed.
    but now the functionality is not working the same way... I have to press the button again and again continuously to increase or decrease volume
  2. akks
    KitKat Dec 8, 2020
    akks , Dec 8, 2020 :
    Take your phone to a nearest Service centre
  3. J4t1np4r3kh
    OnePlus Accessory Tester Dec 8, 2020
  4. 154326789
    Cupcake Dec 9, 2020
    154326789 , via OnePlus 6 , Dec 9, 2020 :
    It's not device problem it's software issue.
    I updated my op6 to 10.3.7 and now I'm also facing same issue. said:
    I got a fix for this issue, it's simple download any volume styles apk and then setup the volume style you prefer and then give all accessibility permissions and see if the new volume panel works whit long pressing volume key.if this works just uninstall the apk your stock volume key will work like before it was supposed to be...
  5. YashJ09
    Eclair Dec 10, 2020
    YashJ09 , via OnePlus 7T , Dec 10, 2020 :
    I tried this but when I uninstalled the app the issue comes back
  6. V1545648509603
    Cupcake Dec 10, 2020
    dameywestside and luchvk like this.
  7. luchvk
    luchvk , Dec 10, 2020 :
    I have the same issue. This isn't the first time that a feature I use was removed or changed. This one is particularly inconvenient because it's one of the functions that I use the most.
    Hopefully it's just a bug that will go on away in a future update.
  8. #8
