22
VOOC Charging seems to be working :)
  1. Patrick Hill
    Honeycomb May 16, 2014
    Patrick Hill , May 16, 2014 :
    I plugged my OPO into my Find 7a VOOC charger at 1:04AM and I was at 8%, at 1:24 I was up to 29% now at 1:32 I'm at 36% so it is charging at 1% a minute :) And just so you guys know the quick charge will charge quick until the phone gets to a certain temp and then charges at normal rate. I guess this is to prevent heat damage
    ThijsOne+1, klabauter, Ukali and 19 others like this.
  2. Youngviet
    Jelly Bean May 16, 2014
    Youngviet , May 16, 2014 :
    vooc charging is quick charging?
  3. sahaven7
    oziboy, TechNique and Linkwint9 like this.
  4. Ryan
    KitKat May 16, 2014
  5. Youngviet
    works on every phone?
  6. pawv
  7. beleaf
  8. psymin
  9. rth121
    Ice Cream Sandwich May 16, 2014
    rth121 , May 16, 2014 :
    Yup, according to Oppo that is. They call it VOOC Rapid Charger
    yossigrosskopf likes this.
  10. Patrick Hill
    No, only phones that support it. If the phone doesn't support it then it charges at a standard rate (but with 2A)
  11. Youngviet
    Where can i get this charger? Or is it built into the phone so that it absorbs more energy?
  12. teqnix
    Lollipop May 16, 2014
  13. rth121
    Nope. Some phones can't even use that plug, it's "too long" for some phones like the HTC One M8, Samsung Galaxy S5, etc. from the videos that mentioned it.
  14. lestergoh
  15. rth121
    It's an Oppo Charger, not sure if you can buy the charger by itself. I think it's somewhat built into the phone.
  16. Patrick Hill
    not true. I used it on my m8 as well..
  17. Youngviet
    thx for the insight, gotta love OPO
    hmsq and Cali_t like this.
  18. rth121
    I don't know then... I think Pocketnow and maybe Android Authority tried using the VOOC Charger on other Android phones and it didn't fit or won't charge...
  19. Youngviet
    but it retains itself at a certain temp so that it doesnt kill the bAT
    lestergoh likes this.
  20. theslimshadyist
    theslimshadyist , May 16, 2014 :
    That's good to hear! My N5's rate of charge is about 1% per minute as well and it does include the quick charge feature.
