Vote on your experience with battery life on Oxygen OS
How is your battery life with Oxygen OS
  1. Much better than CM11
    2.3%
  2. Slightly better than CM11
    20.5%
  3. Significantly worse than CM11
    40.9%
  4. Slightly worse than CM11
    36.4%
  1. reubencj
    Donut Apr 13, 2015
  2. Maximus Decimus Meridius
    Marshmallow Moderator Apr 13, 2015
    Majamulli, cdisxm and Lunatasian like this.
  3. mydroid
    KitKat Apr 13, 2015
    cdisxm likes this.
  4. carvados
    Honeycomb Apr 13, 2015
  5. wmm
    KitKat Apr 13, 2015
    wmm , Apr 13, 2015 :
    I'm referring to the life after fixing the Play Services wake lock issue. Until I did that, it was significantly worse. Now it's as good as or better than what I had before installing OxygenOS.
  6. reddybandi
    Eclair Apr 14, 2015
  7. cdisxm
    Jelly Bean May 21, 2015
    cdisxm , May 21, 2015 :
    If you asked how it is against CM12, then OxygenOS would chew up more battery life, but that's because it turns a lot of unnecessary things on by default. Just by turning them off and fine tuning the wake locks and setting the CPU governor, SOT is improved significantly.
