Network/Connectivity VoWiFi calls dropping on T-Mobile
  1. vonKemper
    Eclair Sep 6, 2018
    vonKemper , Sep 6, 2018 :
    I have VoWiFi enabled on my OP6, and I have T-Mobile as my carrier. I have a great network connection at home, and I use VoWiFi (WiFi calling) while home. For the last few days, my calls have been consistently dropped somewhere between 5 and 10 minutes after call connects.
    Has anyone else had this problem? Could someone suggest troubleshooting steps?
    Thanks in advance!
  2. dz326c
    Cupcake Sep 6, 2018
  3. McRussin
    Froyo Sep 6, 2018
    McRussin , Sep 6, 2018 :
    I have had similar issues. Since I went to the open beta 1, I haven't seen as much of an issue but I know what you mean. The same thing would happen to me and I ended up turning it off for a while. Sorry I don't have any help to give but you aren't alone.
  4. the_o2
    Marshmallow Sep 8, 2018
    the_o2 , Sep 8, 2018 :
    You can try this
    Settings > Backup & reset > Reset the Network settings
    And restart your phone..(remember it will delete your saved Wi-Fi/Bluetooth settings)
    If still problem you can submit this issue here
    https://forums.oneplus.com/feedback
