VoWiFi is not working in my OnePlus 7 pro via OnePlus 7 Pro
  1. V1565280997329
    Cupcake Apr 1, 2020
    V1565280997329 , via OnePlus 7 Pro , Apr 1, 2020 :
    VoWiFi is not working on my OnePlus 7 pro.. Earlier is was working with Airtel sim but suddenly it was disappeared. I couldn't see VoWiFi on top of status bar. It doesn't enable WiFi calling while make call to.others.
    I have checked all the settings WiFi calling is enabled for both jio and airtel sim but no luck.
  2. AbhilashSaikia
    The Lab - OnePlus 8 Pro Reviewer Apr 1, 2020
    AbhilashSaikia , Apr 1, 2020 :
    Hey!
    It might be due to an unstable internet connection. Also, can you follow these steps -
    1. Enable Airplane Mode
    2. Disable Airplane Mode
    3. Enable WiFi again
    Can you check if VoWiFi is triggered after toggling Airplane mode?
    Regards.
  3. V1565280997329
    Cupcake Apr 1, 2020
    Hi Bro,
    Have tried everything but no luck.. My internet looks stable.. Have attached screenshot.. It doesn't shows VoWiFi on the status bar. I could see VoLTE.
  4. AbhilashSaikia
    That seems like a pretty solid internet connection. Can you go to Settings ->WiFi & Network -> SIM & Network -> Select the specific SIM -> Turn off WiFi Calling and then turn in on again?
    Please let me know if that helps.
  5. V1565280997329
    Cupcake Apr 1, 2020
    Tried the same.. It didn't work either.
  6. AbhilashSaikia
    That's weird. Have you checked with other devices that are connected to the same WiFi network?
    Also, I would like to report this issue using the Feedback section of the Community. Please DM me if you require additional help in reporting it.
    Hope that helps!
    Regards.
  7. V1565280997329
    Cupcake Apr 2, 2020
    V1565280997329 , via OnePlus 7 Pro , Apr 2, 2020 :
    I have only one WiFi calling options device that is my OnePlus 7 pro.. Still I am unable to use WiFi options... I have tried belo
    Network reset steps;
    go to settings >> system >>reset options >>Reset wifi, mobile and Bluetooth and check with the issue.
    Still I could see VoLTE not VoWiFi.
    Is there any other way to access my VoWiFi?
